  • Replies 72
from ferni's first link
Different materials coefficient of thermal conductivity
Air 0.025
Aluminum 220
Titanium 7.4-22.0 (Depending on alloy and temp) Usually roughly equivalent to Stainless Steel.
Steel 46
Stainless Steel 15
Copper 401
Concrete 1.0
Glass 1.1
Rubber 0.16
Wood 0.04-0.4
Cork 0.05
Ti and stainless steel are roughly equivalent. What are the factory ones made from?
I call magic beans. get some hardwood pads :O
Somebody get me some drawings and I can get them cut up, in whatever thickness and material you want.
How would determine the effectiveness of the different materials?
sounds good, but I reckon buy the time we buy some titanium sheet in the right thickness, then your time to cut them out, and we need 2 per caliper I reckon even if you did it at cost and donated your time free it would be a $100 proposition. what do you reckon pete? I don't even know anywhere that sells titanium sheet.
lol, and I don't know much to begin with either.
alright, I'll hold off on sending my money to seppos for the moment. If I'm not too lazy tonigt i'll trace out one of the factory brembo shims for you. and if you feel inclined sus out what Ti sheet is worth. I'm not sure on thickness? maybe 1mm or 1.5mm.
I think it's going to end up costing about the same Richard. So we might be better of ordering from the states... but we can wait until tomorrow to see what Pete and Troy come up with...
Here is the thing people. You need to be sure you are getting the correct grade of titanium.
I have a little backing plate that i drew up because i was going to do this for my std caliper. There are a few little touches i added to mine that are different to theirs. The reality is you are talking bees dicks here but if there are a few tweaks that add to the thermal capcity of your brakes then you can get a lot out of them. You only have to look at production cars and see how hard they get punted and appreciate that there std equipment is often worse then what Nissan gives our Skylines.
So the reason i didnt go through with this was because i couldnt find the right grade of titanium, one with plenty of vanadium in it. But that came back to mostly care factor, i just didnt have the time or interest to see it through.
I also had my calipers HPC coated with the pistons coated in the same treatment as used on exhaust housings and manifolds. Again , probably a small gain...but a gain none the less. I know for what my brakes have held up well on the track.
You could also be a real die hard and try to run different caliper pistons, but that was just hits and giggles. You would have to be mad to take that upon yourself as you dont want to be R&Ding this sort of caliper mod on the street or track :O But again, its something that could be done to a std caliper...but lets face it...at this point the sloppy / shitty std caliper will be deflectings its little heart out giving you crap pedal feel well before these sorts of lengths give you any real benefit
Just quickly, i have always had an idea that i wanted to try but never measured. If someone has soem new pads arounf can they measure the total depth of the pad and the the available space between the rotor face and piston when fully retracted
So it looks like the correct FMSI for GTR Brembo's up front is D647. takspeed have this listed under their D960 shim.
http://www.takspeed.com/tispeed/index.php?...;products_id=40
PDF of the shim D960 Shim attatched to scale, i checked it against a set of my pads and it looks right.
Think i'm going to order a set of these. Hopefully get them before PIARC on 20th.
brakeshim_D960.pdf
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
