hi, i'm new to this forum.
recently i replaced the blown engine out of my r33 gtst skyline with another one that i bought off ebay. everything went in and it starts and everything. however, there it has a few problems.
1) the revs fluctuate betweeekn 500 and 1300 rpm.
2) when driving and coming to a complete stop when you have the clutch in it just wants to stall out.
3)there is this fkn loud tapping sound comming from the bottom of the inlet side of the head. ( a few people have told me that it could be the lifters) personally i think the person who put the timing belt on originally it could be a tooth out but would it cause this problem? and the car goes really shit not smooth at all!!!!!!!
4) when coming on boost, the car just backs off by itself liek it sputters and missfires.
ive nearly had enuf of this car lol.. plz help. Thanks in advance
https://www.sau.com.au/forums/topic/190213-tapping-sound-coming-from-engine/
1. Check AAC Value - also related to #2
2. I reckon you have a vac leak in a hose somewhere. Go over them all and find it
3. Could be anything fron noisy injectors, to lifters. Get a mech to check if unsure
4. AFM or, again the vac leak causing issues, spark plugs possibly, coils... could be many things
Basically you have common problems that are all trial and error mate.
Just keep checking parts, and have a read of various 'misfire' threads in this section that go over various problems.
AFM for the idle problem, stalling might be caused by a incorrectly place hose or not sealed like a atmo blow off valve. Also sure its not doing R and R rich and retard. The ticking most likely bad seated exhaust manifold, Check intercooler pipes and what not.
i mean liek a really loud tapping sound at idle.. and this gets louder the more u rev... it sounds like the cam is hitting the lifters
Sounds like big end bearings to me ..... Is it louder when the engine is hot ???
Im pretty sure that if it was a spun bearing the engine would be dead by now as once they go, they don't last much longer so i don't think its that.
If it gets louder with revs its obviously something that rotates and increases in speed so check your timing belt, tensioner, cam gears etc. If not then yeah it could have something to do with your cams/lifters.
Hi,
I've got the same problem with loud tapping sound on my R34 GTT except that it isn't always there, it's intermittent. I suspect VVT as it's comming from around the same area where VVT is situated on the intake cam. I know that SR20 from S14 and S15 are notorious for noisy VVT so I suspect that RB might have the same problem.
It'd be interesting to know what your mech's verdict would be.
i had that for a day or 2, turned out to be my radiator fan hitting the intercooler piping :P
Haha, I had the same problem. I removed the insulation from under the bonnet and problem solved. Seems the bonnet+insulation was pushing down on the i/cooler piping and as a result the fan was hitting it. :P
  • 1 month later...
This may be a few things.. but i think its the oil not getting up the top of engine quick enough? What viscosity oil are you using?
not sure wat oil, i put synthetic oil that was recommended from autobarn
they looked up my car in a book?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
