R34
1 - First pull out the ashtray and undo the screw behind it.
2 - Pull up the gear stick surround and undo the 2 silver screws at the bottom left/right of the storage bin.
3 - Using a thin flat blade screwdriver on the left side, prise out the 2 vents at the top of the console and disconnect the unit.
4 - Undo the 2 silver screw at the top of the heater controls.
5 - Pull out the heater controls, radio & stage bin (all in a cage together).
6 - Remove the radio from the cage (2 screws each side) and fit your radio.
7 - Refit going from step 5 back
https://www.sau.com.au/forums/topic/190825-head-unit-removal/
Nice guide :/ here's the 32:
R32
1. Pull out ashtray like below, undo two screws behind it
2. Flathead screwdriver under the rear of the center console, push up, it will pop out
3. Flathead screwdriver under the top half of center console, pops out, remove center console, or turn it around
4. Undo 4 screws, two either side of headunit, pull headunit out
5. Undo cage holding onto headunit, refit to new headunit, finish wiring off and put back in hole
6. Refit going backwards from 4 :D
was I your guinea pig chris???
keeep it on topic guys.
my intent was to get this stuck to the top so everyone would stop asking how to get them out and stop filling my PM box u :spank:
jon,
can't remember done too many of the things.
  • 3 months later...
R33
remove ashtray
remove 3 screws
unclip panel around shifter
remove two more screws below radio area.
unclip main surround
unclip wiring from: clock,hazards,rear demist , A/C temp sensor, electric mirrors
remove main surround.
remove 4 screws from radio assy.
unclip HVAC and radio wiring.
contact me for pocket,harness and antenna adapter
remove 4-8 screws from radio and put yours in place.
reassemble.
Edited by Chris Rogers
  • 2 months later...
R34
OK I used Chris's instructions and a couple of extra things that he told me about so here is a slightly more detailed description with pics.
The ashtray just pulls out with no significant force needed. I just pulled on the open lid.
This takes a bit more force, I pulled from the back near the handbrake and levered it up with my fingers. I also pulled off the shift knob at this time but you could probably do it with it on but I thought it would be easier with it off. There are 2 screws at the front of the knob, put the shifter right back in low to get easier access. It takes a little bit of maneuvering to get the surround over the front of the shifter indicator and be careful not to scratch the vinyl with the hard edges of the surround. Unplug the lighter, lighter surround light and steering wheel shift switch. All plugs have a release tab, push it in or you will get real cranky trying to get em off.
3 - Using a thin flat blade screwdriver on the left side, prize out the 2 vents at the top of the console and disconnect the unit.
This is the panel that houses the 2 vents and the hazard switch. I used some masking tape around the screwdriver to avoid scratching the vinyl when levering. Unplug the plug at rear.
4 - Undo the 2 silver screws at the top of the heater controls.
I put some toweling over the lower console area to avoid scratching the vinyl.
I undid a couple of extra screws to "open" up the cage a bit to allow the radio to be removed and the new one installed more easily and without scratching anything.
Mine had the aerial adapter already fitted as there was already an aftermarket deck installed but the previous fitter had butchered the wiring loom so it was a bit more work to re-wire all the wires in a decent manner but if you are removing the stock deck then get the correct plug adapters and aerial adapter available from Chris or some auto outlets. I also bundle any wire slack in some padded tape to avoid any rubbing or rattling later on.
I connected everything up and tried all deck functions before re-fitting the cage permanently just in case but luckily for me all went to plan.
Hope this helps, Mark.
  • 5 months later...
  • 1 month later...
  • 1 month later...
this really helped me out!!
I just thought i would add that to get the gear surround out it actually a little lever point for you to put a screwdriver by the handbreak at the back. i was having trouble working out how to get it off untill i spotted that.
  • 3 months later...
  • 3 months later...
might sound stupid but, how do u disconnect the plug behind (the wire connection) the car lighter, there are two of them, one is bigger than the other... seems like it would not come off however from the picture above, obviously 2KR34 can took them it off..
i just dont want to break it because i use it for a lot of thing to charge my ipod, gps, and when i left my lighter.... basically half of my life depends on it.. :)
pls help someone
its for a 34 btw
cheers
bly
  • 6 months later...
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
