I think you'll find it's not because you have a whale..
it's because you admit to having intimate feelings/emotions about a vehicle.
or it could be that they immediately assume you also like Fat chicks which is a sick thought on it's own.
They're all like "oh.. you "love" your r33 skyline hey?"
they're thinking "what a sick bastard.. I bet he get's his end wet in fat chicks too... *shudder*"
:ermm:
  • Replies 77
always been facinated about the 32 GTR through school... so the skyline ended up as a dream car (pretty realistic).
then on an adelaide trip i tried my luck at test driving a 33 at the car yard just for fun...... came home with the car... not much bad i could say about it at all.
has everything and more :
Power,
Size,
Fun,
demands respect (from driver that is) :D
In general, Aftermarket support, Onlookers attention
For the GTS's . Even without the turbo most people still mistake them as being turbo, tough looking car perfect for the new driver to legally step into an import
For the GTS-t's. (Me) Fantastic budget performance car, esspecially when you compare it to the local market around the same price. Good performance, responds well to mods. Capable of being good at any obsticle you throw at it, (drift, circuit, drag, show) etc.
For the GTR's. Cult Following, Capable of being as good as just about anything in any motorsport application provided you have the budget, proven track status, look hot. A realistic Dream Supercar esspecially with prices as low as they are atm.
Does any one else notice that little kids that can barely count, some how know what a skyline is and yell out "Skyline!"
Or is it just me?
I love my car because she is sexy and sounds like a Jet :rolleyes:
33's have a cup holder! what are you on about?!
Next to the hand brake, albeit it sux, but that's not the point!
thats a cup holder !?!?!?!?????
the square space just rear of the coin slots? no way
is mine missing something? coz that's not gonna hold a cup securely. someone post a pic preeeez.
Edited by Munkyb0y
Yeah that's ment to be the cup holder. Maybe the Japs hold their noodles in a square cup :yes:
I think an American designed the cup holder... :yes:
I think an American designed the cup holder... :D
If they did then it would have been big enough to hold a 2L maccas cup.
Skylines are great bang for buck, especially R33's. Good space without being a massive car, even in stock form they are quicker than a lot of other cars out there, great sounding engine, good brakes, and of course the taillights. Only problem is the boot space.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
