Hey crew,
Just blew the turbo on my car, its the old hpi r32 4door drift car. Most of you would know the car?
It was running a kkr 480, what would be a good upgrade similar to this size turbo? it was running 250kw at the moment on 20psi... rb24 stroker motor. Also wondering if I will have to open up the motor or not as I poured alot of metal out of the cooler and pipes!
Any ideas would be great!
Thanks Joey.
Edited by white32
  • Replies 55
Personally i would be sending the turbo back to KKR and askign how do you explain such a catastrophic turbo failure. I personally woudl carefully rip off the inlet pipe to the throttle body and see if there is any debris in that pipe, up to /around the throttle body..
The intercooler woudl tend to be a reasonably good filter for crap boing through, but fine particles woudl still most likely get through. Perhaps pull the plugs and crank it over for a bit to clear it????
Best consult a trusted mechanic me says... :D
thats rather horrible... i would consider buying another cooler also since its going to be too hard to get all the shards out your current one.
Consider a garret GT3071R IW T3 housing and you'll crank big numbers with better responce
seems to be a few KKR's dropping off....GEN TT just stopped using them also, i hope they can sort out the issues for all the tight asses out there :P im sure it is just one of those things, im pretty sure the oil control issue is sorted now. ive not heard of another failure like this though.
slap on a 3071 or a td06sh-25g
Wow, that is a serious failure right there! Were you doing anything out of the ordinary?
Just floored it in 2nd gear bounched the Bee-R rev limiter once then ka boom!
nO FUN...
Thanks for the replies guys. Will go to local mechanic some time today, on foot god dammit...
nO FUN...
That explains it... cheap turbo and crazy shaft forces caused by BEE-R rev limiter.......
that doesnt look good!
im running kkr480 turbo aswell, run around about 1.3bar or 19psi daily thru it, but ive noticed mines water cooled and oil cooled..why is all the kkrs ive seen are only oil cooled? hmmmm
Not sure on that one? You must have got lucky! Good luck with yours, hope it stays together...
post the bits back to them with a thank you card. that is a heap of crap. it looks to me like it failed in part due to the cheap arse materials. I mean look at the way the compressor cover backing plate has just exploded. what a piece of junk.
yeah i think he has got something to do with them in a big way - ever noticed how hpi started pushing all things otomoto?
preety sure he is a member on here aswell and might be able to hook you up cause it dosent look too good having the hpi project car with the turbo that they push have a massive failure
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
