Hey guys,
I have another switch question. I picked up my S2 Manual Stagea and have seen a switch on the dash which is to the right of the steering wheel.
It has a pic of the windscreen and wiper and also looks like it has a wavey water level at the bottom of it. If I press it the only this it does light up an orange light on the switch itself.
Sorry if its hard to explain and my camera is buggered at the moment. The switch also is not an on / off switch. if you press it down it will flick back up and the light will come on and if you press it again it flicks back up and the light turns off but it doesnt seem to do anything.
Im assuming it has something to do with the windscreen of washer bottle but I have no idea what it would do!
Cheers
Dave
p.s. I am loving the stagea!!! I had no idea they were so nice to drive!
https://www.sau.com.au/forums/topic/191695-dash-switch/
hahaha well i dont think ill be using that any time soon, cheers.. I guess I can't really test them then? how does it work?
Put your wipers in the freezer for an hour, pop them back on, time it with/without switch on to see how long before the defrost. :laughing-smiley-014:
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-3448454
The "Wiper de-icer system" usually came with a cold weather spec pack which also included heated wing mirrors, rear fog lamp, bigger battery, better heater, bigger starter, & if you coupled that with the "S Pack" you would get a rear viscous Limited slip diff (LSD)
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-3452124
and the remote start option maybe? or is that something else again?
'Fraid not, the remote starter was a seperate option...
Type A starts or stops the engine
Type B starts & stops, alarm function, locks & unlocks the doors.
Type C starts & stops, alarm function, auto rear demister if ambient temp is less than 5 deg, and answer back function
Type D starts & stops, alarm function, lock & unlock, auto rear demist, & answer back which basically sends a signal to the car (at up to 300m away) the lights on the car flash, then the little LCD screen displays the car temp, if it's locked, if the alarm is armed, and if the engine is running or stopped among other things...
All of these were only available on the auto
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-3453336
Holy crap. That's just the remote start options???!! I'd choose... type D :(
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-3453531
Nice, my stagea just keeps getting better... It is the 'S' and has the rear fog you mentioned as well.. I love it, I can't believe it took me so long to decide to get one!
rear fog? whers that ands more importantly where is the switch?
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-3461215
  • 1 year later...
rear fog light is for they really foggy days, say if you can just see the car up ahead that is only 20meters or so infront, well then i guess the car behind you can just see you too.
fog light is really bright, and being red they will know that there is a car infront and thats your car they can now see.
little switch is for the wiper arm, if you have snow on your wiper arms, thick snow, that basically heats up, melts the snow around the arm to allow it to move much easier. :D
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-4451083
Hey there
The switch that you are talking sounds like it could be to heat up your wipers, you can tell by having a close look at your windscreen, if it does have the heating elements in the glass they are orange in colour and usually have three long strips where your wipers sit in the off mode. If the heating elements are in the black part of the glass (ceramic) it will be very hard to see but you should see them.
If you do happen to have the heated windscreen make sure you have glass cover on you insurance, if you think the price of a normal windscreen for a stagea is expensive wait till you find out how much a heated one is!!!!
Edited by Punk72
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-4451095
the switch heats up your front windscreen... if you look at your windscreen you can see a few lines of that demister strip around the outside... turn it on for about 5 minutes and touch the windscreen near the strip, nice and hot... i didnt know it heated up the mirrors... will come in handy in winter when im down at the snowys...
p.s. i was lucky enough to have remote start type b... theres a few tricks to using it tho which is good... push the start stop button twice the car starts... push it once it stops... push the other button twice alarm arms and locks doors, once will disarm and unlock... only thing that shits me is once the car is running it will turn off when you open the doors... i am thinking of a timer circuit that holds the door switches on for like five minutes so you can get in the car put the keys in the ingnition... as soon as the keys are in the ignition its orite... if you have the window down and put the keys in the ignition its sweet as so it wont be too hard to come up with a circuit...
neway ive got a stagea to wash
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-4451745
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
