I saw James today in his 'ice green' R33. He was at the lights, down at southport. And I was in the work ute, and it was pi55poring down with rain, and I was lost. Other wise I would have yelled out the window and stuff.
Anyone seen or own the white R33 GTR that gets around down at mooloolaba a bit. Saw it on monday driving near the sunshine plaza when it was raining, sounded pretty good. had a vspec sticker on the boot lid and looked like the brakes on it were pretty big last time i saw it.
I saw a white r33 towing a trailer through mooloolaba yesterday
Also a dark blue R32 gtr parked on buderim-mooloolaba rd the last few days
The dark blue 32 gtr, if it had white work wheels, belongs to someone on here, his usernames Dynamix.
ROFL!! It's true, it's sad but it's soooo true....
Last night in valley saw R33 "6IRLY" parked in valley last night, GTSt with GTR kit, eyelids, lotsa stickers, chameleon paint. Is it just me or is it hellishly brave to park a skyline in the valley on a friday night all night?! I wouldn't be able to relax if I knew my car was out there....
The Lady that owns it works at The Cabaret Club....She is a friend of a friend
Saw afro at Sumner Park today, I was beside you for a bit in the silver 33 sedan.  Was in ordering some new extractors for the mini, the old ones split last night  :) .  And they say GTRs are money pits!
ohhh so that was u,,,cool,,
i waved,at ya, :rofl:
dont worry dale82au hardly anyone sees me either im always out lol...
does anyone know the owner or a blue N/A R33 series one Rego REG45??? owner of that car proved to be a d***khead last nite , was on the M1 cruising along this dude nearly side wiped me off the m1 !! talk about reckless driving i got his plates so the cops have been notified..
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
