She sure is everybit female :)
Had no idea.... I didnt go and say hi cause i figured it was not the user on the forums....
Common mistake.... Just assumed it was a bloke... Sorry NVS04
Ill say hello next time....
Thats Amanda, she used to own a REALLY nice looking blue 180SX, hence the plates.
Saw a grubby 1980's toyota 4WD import van of some sort (hiace,torago) on the M1 just near the coro drive turnoff before the gateway... with a SAU sticker on the back, :lol: anyone from here??
Ohh and saw a maroon 32 yesterday morning at the maccas in redcliffe..
Ohh and saw n15m0 (888INZ) on tuesday (i think..) at the shops in redciffe, parked near the ANZ bank , suspiciously right outside the hair salon :D
Spotted EZY34 on Tuesday night cruising it towards cleveland or birkdale. VERY NICE 34 GTR....remember to wash it though....it would look nicer.
i see that car all the time at the casino. its a really old guy driving it and im not sure if its a GTR or not. someone was telling me its only a GTT with GTR badges on it.
do u guys know anything about the white EZY34?
This one was being driven by a young Asian fellow with another asian fellow as passenger. Definately a GTR 100%
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
