She sure is everybit female :)
Had no idea.... I didnt go and say hi cause i figured it was not the user on the forums....
Common mistake.... Just assumed it was a bloke... Sorry NVS04
Ill say hello next time....
Thats Amanda, she used to own a REALLY nice looking blue 180SX, hence the plates.
Saw a grubby 1980's toyota 4WD import van of some sort (hiace,torago) on the M1 just near the coro drive turnoff before the gateway... with a SAU sticker on the back, :lol: anyone from here??
Ohh and saw a maroon 32 yesterday morning at the maccas in redcliffe..
Ohh and saw n15m0 (888INZ) on tuesday (i think..) at the shops in redciffe, parked near the ANZ bank , suspiciously right outside the hair salon :D
Spotted EZY34 on Tuesday night cruising it towards cleveland or birkdale. VERY NICE 34 GTR....remember to wash it though....it would look nicer.
i see that car all the time at the casino. its a really old guy driving it and im not sure if its a GTR or not. someone was telling me its only a GTT with GTR badges on it.
do u guys know anything about the white EZY34?
This one was being driven by a young Asian fellow with another asian fellow as passenger. Definately a GTR 100%
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
