Oooh!! Karen is going to be very upset when she reads that post!! Her car is a series 2 RED R33. Factory spec. NOT Burgundy or wine red or Maroon it is red. Hope this clears up this little matter before she gets huffy!!
So what colour is it really? Is it bright red? Like fire-engine red?
Hey hey i thought it was some commodore smuck trying to race me...
Wasent til you were passing that i noticed it was a skyline...
Lol... Have not seen your car before... R34's look the seesnaz...
What do you mean catch up... I was driving in my usuall morning granny state on the way to another exciting day of work... LOL
nah i got like every red light, so when they went green i was catching up.... :( but not speeding :) i read elsewhere that u worked in aspley so i knew i had not much time to finally have a club member see me...
once again, very nice car.
If that is the factory paintwork that is INSANE (although in that light it did look burgundyISH) LOOKS HOT .
Karen, Did you get the skyline panel colour coded on the boot?
also spotted yesterday morning on Race course road a grey r32 gtr, plates 60zla or something, i met u down at anzac avenue in redcliffe, but im sorry i cant remeber urs name..
Car: burgundy R33
Rego: SMR33 :(
Where: Milton Road, Toowong
When: Wednesday evening i think it was around 5.
What was I doing: Crawling in traffic like I was trying to get my mate to the airport.
Also, holy cow the paintwork on your car is awesome.
Thankyou muchly :D
Huffy eh??? No chilleh for you :)
Yes, S2 red is a solid red, not metallic. It can look darker in the early evening.
Glad you liked the colour, people do ask if it’s resprayed, but its not I guarantee it. The car has the factory optional Super Fine Hard Coat, which is an additional clear hard coating over the paint, which has helped it to stay in great condition, plus I detail it every week :D
The skyline panel at the back is painted the body colour on all S2 R33’s :)
I was wondering how long it would take Karen to spot the post... :(
Anyways on topic
Spotted a R34 GTR (unknown colour or plates was pitch black)
Where:Up Mt-Cootha
When: Tonight about 7pm'ish
What doing: Using 4wd to the max.... Fool....
I was wondering how long it would take Karen to spot the post... :P
ooohhh you're a cheeky one too :D
Anyways back on topic…I spotted:
Car: Black S1 R33 with GTR wing
Rego: 810-OFF
Where: At Jephson St & Sherwood Rd intersection, Toowong
When: Tuesday 18/4/2006 @ 8:25am
What was I doing: Waiting to cross the street
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
