spotted n15mo yesterday on coro drive... :sleep: I was looking at the car through the window @ work :kiss:
Haha damn u've got good eyes@! :)
Spotted a few today worth mentioning
1. White 34 with full bomex kit and white wheels parked along Logan Rd, opposite Umart.
2. Yellow 34...looked like 00R34 but can't be sure...along Logan rd then turned onto padstow rd
3. White 33...white I was turning into Daw Rd...got a wave! and waved back.
4. silver V35 coupe in the valley...yummmm...
spotted a white 33 with sau stickers on loganlea road just before 7
a maroon 32 on the m1 near springwood just after 7
and a silver 32 at the queensland fire and rescue training centre at the port of brisbane
I spotted this one as well :D
And after I u turned it at the lights after, spotted a 4 door 32 following me for a few hundred metres after
could have been my car? yours was the silver 32 that turned off just before the motorway overpass this morning? sorry i didnt wave if you did, my g/f was following me in her car and i was distracted lol
I spotted a white 34 GTR (???) next to a black 33 heading into the city on sandgate road at nundah about 6, then saw "600DBY" on Gympie rd at Strathpine at around 7:30 tonight
Spotted another yellow 34 today driving on logan rd towards underwood...i only saw the top half of the car coz of the cement barrier.
Also White 4 door 34 99GTT on logan road just outside the cop shop near garden city with a for sale sign
And...a silver 4 door 33 I was following on the M1 towards Gold Coast...right till Smith St exit...if u read this..mate, I wasn't tailgaiting you...was at least 2 car lengths from you but you seem to want to get further away from me :)
yep that was me! woo hoo i've finally been spotted!!! ( well sort of) i was thinking of painting my car pink so someone would notice it . i even work with 666dan and he has never spotted my car :D
And...a silver 4 door 33 I was following on the M1 towards Gold Coast...right till Smith St exit...if u read this..mate, I wasn't tailgaiting you...was at least 2 car lengths from you but you seem to want to get further away from me :D
That yellow 34 was me near the Carlovers car wash flashed my lights at you doubt you could have seen it ...
yep that was me! woo hoo i've finally been spotted!!! ( well sort of) i was thinking of painting my car pink so someone would notice it . i even work with 666dan and he has never spotted my car :(
think i spotted you on loganlea rd again this morning, just before maccas, i was going the opposite way... just before 8am
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
