Spotted, bout 30mins ago, gunmetal grey R34 Sedan with plates sxc34 with a short arse blonde driving, I thought it was a 9yo child at first, could hardly see her head as she turned in front of me...... :(
Spotted Garry (GAZ33) on Strathpine Road tonight. I was following you up until you turned off towards Brendale.
Ha Ha .. that was you ...
did u notice how I was sticking to the speed limit .. making sure to keep the other car beside me so u couldn't change lanes and pull up beside me. thinking to myself .. this car behind me is itching for a run and I'm not even going to entertain the thought.
didn't even pick the car behind for a Skyline ..
Thanks Chris .. the first person not to mention the "Big Ass Wing" in a spotted Gaz post :ninja:
Today is the day of the black R34 coupe's it seems.
Saw another on my trip home through redcliffe, GTT XXXKAB (not zennon though, just similar plates).
should add, also saw a dark coloured cefiro around the same time I first spotted the 34, just leaving the hornibrook bridge
phatboi spotted on the way home today
blue = purty
shame my blue needs a good clean
i miss washing my car :P
Lol i spotted you and had to tail gate the car infront to wave :laugh:
the rain made my car dirty anyway :( i regret washing my car :ninja:
spotted a maroon 32 on logan road around 1pm today. got a big ass smile from the driver. i am taken, sorry mate.
that may have been me i was on logan road at around 1 and i seen a silver 33 drive past look at me and nod i looked back at u or who ever was driven it and got a nod back but i prob had a smile on my face at the same time... what u mean about this ur taken :( im a dude.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
