Spotted 5EXYN turning on to mains rd at Sunnybank..
Also a gunmetal grey 32 on mains rd too this afternoon around 5pm heading towards the city, had white wheels...
Oh..and a phat white 33 with white deep dished wheels also on Mains Rd heading towards sunnybank hills!
Spotted coming home from work this morning approx. 1045 on Cunningham H/Way, one very nice Bay-Blue 34GT-R heading Willowbank way.
Then spotted a black 34 sedan or coupe (couldn't quite tell between the shrubs) on the Ippy motorway heading outbound near Riverview.
The GT-R was F**CKN' HOT!
spotted a red r33 coupe at kallangar this morning, chick driving i think, had a huge NISMO sticker on drivers door.
Also spotted red r33 coupe in my street in a spare feild of grass mowing the lawn :(
Spotted Blue GTR Gold wheels (i think) Plate IRVING??? something like that, waved at ya on Nicklin Way Kawana.. I was in the silver 33...Nice car though (I want one)
Edited by O.I.C Napster
Also spotted red r33 coupe in my street in a spare feild of grass mowing the lawn :P
spotted a silver 34 GT-t parked across the road from me when i was mowing the lawn last night...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
