Saw a grey R32 GTR coming outa Brookside carpark and you followed me up Samford Rd for a while until you turned off.
Saw an R33 000 PLZ on Beams Rd.
A blue R34 GTR with a huge black wing near Chandler.
A black S15 200MU at Tingal Rd Wynum.
saw 70YRB gettin a good talkin to by the coppas at broady car park on sat nite, what was that all about????? love the rear lights u have on that 32 btw
Edited by long33
spotted a few skylines in allstar this morning, also a r32 gtr and a white r34 sedan few buildings down rom them,
also spotted a r32 GTR plates gdz11 or something in redclife
Mine was the pretty silver R33 under the blankets........
I saw this flash of silver r 32 plate fynr32 on the ipswich highway merging in :pwned: and it then locked them up anyone seen this car?? :laughing-smiley-014:
it was me. ss in front of me thought he was quick till i got traction. saw he was gonna block me with a truck when we were about to merge so i hit the brakes. didnt even realise i'd locked up till i saw the smoke in the rearview
Edited by FYN_32
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
