i live and work in toowong and i have never seen another gtr.................
starting to feel all alone
i just want to be held
See a few getting around toowong. All 32's though, haven't seen 33 or 34 gtrs there. Truck loads of gtst/gtt's but.
there's a burgandy R32 that's parked at the house on the T intersection on high st and benson st.
I spotted a black s2 33 and a white s1 33 on the m1 near beenleigh south @ 5.30am. The s1 followed me for awhile.
I also spotted a white 34 gtt with a sheila driving (Miss Niz?) in Sherwood around 3.40pm.
Miss Niz = Sheila lol! :cheers:
spotted a white (pretty sure it was a series I) coming up the hill into mt.gravatt uni @ griffith. wat were you doing there? Had SAU stickers in the rear corner window.
Hahaha, Sheila, yeah thanks...
Nah it wasn't me, although i do work round that area. My 34 hasn't left our garage in over 2 weeks now. I've been driving my new daily driver, VT wagon bogandore every day...
Spotted 58ATN on Gympie Rd over the weekend. Looks nice and tidy, I have a sneaking suspicion I saw that car a couple of years ago with different plates though... new owner?? Or am I imagining things?
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
