was neone on here parked at the corner of rafting ground road and moggil road in brookfield this arvo around 5ish, if so really nice 33, nizmo 400r front bar and carbon bonnet, looked really nice.
I saw a white 33 with 400R front bar and carbon fibre bonnet on the big roundabout around the Ford dealership on Moggil Rd at about 12:30pm. Very nice, wanted to get a closer look at that bonnet. Anyone from here own that.
There's a White S2 33 GTT parked behind me at the Novotel Today... belong to anyone here? has a 33 GTR rear wing, and 17" IndyR rims...
Damn your car's low :D I though mine was dropped as far as it would go, but it's interesting to see the two cars next to each other.
Also I parked next to a wine red 32 GTT out at redcliffe yesterday about lunch time. anyone?
Yeah, that was me... Is yours the black one with the stealth rear spoiler? If so i've seen you round that area a few times. Nice car - love the black lines... :)
And that was me too... ;)
I remember seeing you. Gave you a wave as you went past. I'm always out and about in the Indro - Kenmore area so say hi if you see me. Just got a new computer, boost control and fmic so car is running pretty well!
A couple of weeks ago I saw an R34 GTR driving along Moggill Rd in Kenmore late at night... Beautiful car, not sure of the colour as it was dark but think it was red (maybe?). Definitely a GTR though as it had the pumped out guards. Anyone seen it around?
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
