who owns the silver 33 that was parked in uni yesterday? it has GTR badges on it but im so sure its a GTS. hmm
LOL they may not own up, I was close to leaving a note under their wiper about that :yes:
Edited by 666DAN
spotted RRB25, r33 gtst, was driving behind it for awhile on aerodrome road, and also a blue r32 GTR. Then a r32 same colour as mine but with a white front bar puling out of a car park on alex hill.
chased Vandit down the gateway in traffic today - horny little bugger you are (this makes sense to vish and myself :whistling: )
ha yes i know iam too ;) you where to quick for me i couldnt keep up :(
seen a blue r34 gtr getting pick on by a moto copper on way to power cruise...
you were going towards the servo with the bonnet up and he was pointing at your tyers
and i seen 83ecks driving past the grandstand, i waved and you looked at me funney haha (i was in the blue singlet)
R35 GTR at maroochydore parked on aerodrome road. plates were THNX (i think). Awesome looking car. I scared my missus (who was driving) when i screamed out that I saw it hahahaha.
They tend to jump a bit when you do that. :ph34r:
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
