White 34 ***LDM over at the Aspley Pizza Hut/McDonalds/Chemist parking lot just before. Not often I see stock wheels on 34s!
and a white 33 leaving Trouts Rd when I was coming home. It seems a few Skylines live in/off Trouts Rd, but none of them except me are members :banana:
Edited by Isola
Spotted Pear on Nudgee rd around 1230 today. I was in a kennards truck heading in the opposite direction just as you come over the rail crossing near kingsford smith drive. Gave a way when I noticed the number plate.
The following takes place between 1pm and 2pm:
Spotted a maroon 33 today (well thursday) coming from Rode Rd, onto the big roundabout, black guy driving it. I gave a wave as I went past you, you stared at me and dogged me, then went the same way as me and made sure you overtook me employing the Vin Diesel 12 and 0 driving position seen here:
but then, you turned off at KFC at Griffiths St. Just couldn't resist the urge ay? :)
While I was being dogged by that car, a red 34 with the big gay nismo wing went past going the opposite direction on South Pine Rd.
...event occurred in real time.
Edited by Isola
He's got your number ;)
He likes fried chicken more than me :laugh:
Last night - white 32 spoilerless and low at the Aspley Chemist at about 10:45. plates were ***LNI - The brunette driving it - Amy (I only know that because the counter girl called out her name. I'm not stalking) was hot :)
Just a shame I pulled up in the Getz instead of the 32. Must have looked real manly :laugh:
Black 32 on Albany Creek Rd tonight about 8ish turned into one of the housing estates near the bowling alley. Sounded nice!
White 33 at Aspley Mcdonalds plates GTS-R33. Custom plates on an NA? Really? :sick:
Silver 33 Albany Creek Rd waiting at the Gayford St lights on my way back home again.
spotted a bronze R35 GTR on gympie road kedron joining the grid lock of friday afternoon traffic.... personalised plate HBTAX
:sick:
didnt like the exhaust note though as it took off down a side st..... then some P plater in a old beaten up merc tried to catch up to you :action-smiley-069:
Edited by BstewyR33
Lambos are just as gay as NA 33s, so I can see the correlation :P
Wonder if the black one is Ty1?
Nah mate i don't have black rims and very rarely go along redbank plains road. I still haven't been spotted yet ;)
Last night - white 32 spoilerless and low at the Aspley Chemist at about 10:45. plates were ***LNI - The brunette driving it - Amy (I only know that because the counter girl called out her name. I'm not stalking) was hot :blink:
Classic... "Amy your meds are ready for your THRUSH problem"
You go "Ewwwww, dirty birdy"
Its "H8 TAX"
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
