Hi, was that you leave a SAU QLD card on my windscreen the other day? My car was park at Brisbane Convention Center!! If yes my name is Alfred nice to meet you, you have a really clean ER34!!!
That was me. I had seen your car there a few times and thought you might be keen to know about the club.
And thanks for the compliment about my car. Considering yours is immaculate I'm happy you think mines in good condition :) Really wish I had the Nismo aero kit on mine.
I saw your car few time at the parking lot too. Yours one is really nice, I believe there is always more than one immaculate skyline in Brisbane. What is the different between SAU QLD and SAU qld section here?
The qld section on the mothersite (this site) is a loose affiliation of Qld Skyline enthusiasts. The club SAuQld is a separate car club. We organise cruises, track days, dyno days, drags, social events and the like. You have to pay to be a member of the club but by being a member you get discounted entry to our events, discounts with our sponsors and so on.
Spotted Pathetic Lowlife 'dream boats' sorry I meant traffic police defecting a brother for no rear eye level brake light and non ADR approved bonnet.
Say again sorry mate... defecting for no rear eye level break light... on a bonnet? rear?
That's the one that was broken down outside work. It's a 33 with a dodgy 34 front conversion.
pretty sure it's had a 34 tail light conversion as well. that explains why it looked so weird, LOL.
and LOL at it breaking down. looks dodgy as
Nah, No rear eye level breaklight - defect
having a non adr approved front bonnet - defect
Ah thanks mate.. I thought you was talking about just 1 defect.
So the main 4 break lights at the back are not classed as eye level?
Saw a white 32 gtr on milton road at 5:40pm this afternoon drive the opposite way to me (away from city). I think I saw an SAU sticker on the quarter window
That's correct mate, for some stupid reason there has to be another above those....
that was my wife Deb that was driving(its her car but shes never on here but she likes doing it up and driving it like its supposed to be so thats a plus haha)
she sms me and said she spotted "that other silver 4 door from around here and we waved at eachother"
got some new rims for it on the weekend as you saw. some varrstoen 18x9.5+30s
next stop is lowering and exhaust and cooler.. all in good time
you may spot my current daily as my cressida broke(pissin out oil into the exhaust and i dont think its turbo:S) its a white bubble shape ford festiva with hail damage on the front 1/2 of the car
I also spotted HLUCN8 on the bruce highway through to nudgee, then spotted him in the arvo from near the shell to the south bound entry ( I was in my festiva that was next to you almost the entire time on the highway that was having a good look at your car my wifes sisters boyfriend now works for australian aerospace doing the pattern cutting of the carbon fibre, his name is Joel he said you used to work there??
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
