I have it confirmed, there is no Australian Nissan with Standard (Factory) GPS. So no Nissan maps, the unit's use an add on box/wiring GPS that is either dealer fitted (option) or is installed at the dock, in the Nissan holding yard when 'imported' for an Aussie owner. Nothing is installed at the Factory...
As stated the unit uses Siemans software via a memory card of which there is a chance I can get to see one soon. Presumeably, it can be replicated. Incidentially it is a $330 spare part as an upgrade and it is installed in the car behind the glovebox of a Murano and Patrol. It stays with the car in order to work and is not downloaded via a disc.
Does this help?
Unfortunatley I don't think this will help. What we need are the digital maps that can then be coded correctley to work off DVD in the right orientation in Aust.
Cheers
Andy
https://www.sau.com.au/forums/topic/194126-software/page/8/#findComment-4077556
Cheers
Andy
Yes I think you are right, but this card will have the maps on them, just not sure what format that they are in.
To compare with my Mobile Phone GPS Software (Sorry if that is a bit crude) that I downloaded off the net, I think that the program that runs the maps will need to be able to read it. So if it is a Nissan Aust part, then the format may be close, even if it is just a Seimans unit.
Either way there is no other unit installed in an Australian Nissan and I don't think we will find another option.
As a guess, perhaps Nissan has a commercial agreement with Siemans and globally all maps are in this fomat. Without finding the files and taking a look at them in comparision with the Japan maps we will never now.
Just a long shot... but one that I will try to investigate.
https://www.sau.com.au/forums/topic/194126-software/page/8/#findComment-4077614
actually no. nissan has agreements with suppliers of maps world wide - ZENRIN - US market. Xenavi - Japan market, Siemens/VDO - Oz market.
been down this path already and I donated a siemens disc quite a while ago.
have a quick dig on this. it has been covered already.
https://www.sau.com.au/forums/topic/194126-software/page/8/#findComment-4100022
The guys from Xanavi in Russia are working on a conversion for the computer from Jap to English for all the screens except the GPS functions. They have said this would be ready around June.
It is as simple as putting in a disc in your DVD rom drive, press a few buttons on screen and then the computer is upgraded to English.
Price is not confirmed and timing still to be locked in but pushing for it as soon as possible.
Cheers
Andy
G'day,
Any updates on the language conversions from Xanavi yet
Cheers
Jason
https://www.sau.com.au/forums/topic/194126-software/page/8/#findComment-4100281
wow just went through all 8 pages. i have a 2003 model i think but it has a dvd rom. can mine be converted :P
but from the imformation i've read no. but just wondering r they making 1 for the 2003 models? and r they making the english buttons?
Edited by skylinesrus
https://www.sau.com.au/forums/topic/194126-software/page/8/#findComment-4103423
English button kits come up in ebay from time to time for V35
https://www.sau.com.au/forums/topic/194126-software/page/8/#findComment-4103524
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
