even if you replace the hex of japanese texts to english, it will require more work to:
- swap km/ltr consumption to ltr/100km algorithm
change the multiplier, I can't remember the offset off the top of my head, but it's a hex value in the firmware.
Didn't realise the timezone was an issue, but that's just a matter of changing the UTC shift, I'll dig around when I get a chance.
As posted above, if you have no confidence in flashing custom firmwares, then please do not attempt this. It is however almost identical to flashing custom firmware on iPhones and Xboxes etc, so if you've done that in the past this should be straightforward.
I'll see if i can put some screengrabs up, as a visual aid.
I know someone may have brought this up or someone has considered it already but ive got an english conversion on my v35 and was reading that 370z has dvd navigation was just wondering if anyone knows if the map disc is compatible at all? Its probably not even xanvi right? any way just wondering if anyone knew would be good to get it satnav working
Hmmm... this could be fun me thinks... dont have to worry about swapping consumption for economy as i prefer it how it is, so it will just be a case of Translation, char sets and date/time.
In regards to bricking, is there any recovery process if you screw up a hacked firmware? or is it a case of just dont get it wrong?
you can hook a JTAG up and recover, but it's best to try and avoid the situation :P
nope, software engine is different. you are correct in your thinking they are both xenavi but the maps are coded different. easier to adapt it. (which I have done already.)
spare box for one. don't screw up is a better option. JTAG - most of the guys won't know what this is.
lol I'm not sure if I did, but I remember saying "if you can mod an xbox you can flash your xanavi firmware". But yes, finding JTAG pins and flashing etc is very tedious, so best not to attempt it if you're not comfortable with that stuff.
Holy crap, that was a huge read. Followed this thread from start to finish - is that part of the initiation? Picking up a 2003 V35 this week (hopefully) so just wondering who is doing the english conversion? I live near Newcastle, happy to trip down to Sydney. Is that still you Andy? Also, not sure I followed everything with regard to the use of the TV/DVD part of the display. Is that possible? Is that the stuff Chris does? Does anyone do it in Sydney? Or is it better to go for an aftermarket TV/DVD head unit? I get that the SAT/NAV cannot work - not too worried about that.
thanks
thanks
Andy or I can do the conversion for you....I'm in Hornsby.....but then again Shan was doing it for free.....sorry my mistake that was hot air!!!!!...sorry my mistake again his now just explaining how to do it for free at your own risk :)
Yes you can get Chris to do the TV/DVD conversion when your up in QLD.....or you can do the TV yourself and then put a DVD player of some description in that suits.
http://www.skylinesaustralia.com/forums/In...p;hl=tv+install
Edited by Jetwreck
Hi there,
It sounds like the V35 Jap to English conversion is something that a lot of people have been discussing above and that it is now possible. Has anyone tried a conversion for the V36 370GT yet. I would love to be able to read the menus on the screen in English and to get the GPS working would be awesome. Mine has this carwings feature and keeps trying to call the operator in Japan! Wish i could speak Japanese! Car has voice commands for just about everything! :blink:
Getting the GPS working is easy, if you get a Garmin GVN53 you can run this through the AUX. That's the easy way :whoops:
I ran mine through the camera system. I turn on the side mirror camera and flip a switch and it goes to navi. The reason I did this is so I can still listen to music while the nav is running.
  • Like 1
Getting the GPS working is easy, if you get a Garmin GVN53 you can run this through the AUX. That's the easy way :)
Thanks for the reply. That's great info. :D
Use search function to find answer.....
I have used the search feature... (spent 2 whole days reading up on everything that has been done and tried)
I see that people have tried using the 350Z maps etc but i want to use the japan maps but change the data in the map files. (again i haven't seen the map dvd format yet {and cant see one online to download}) but I cant believe you cant reverse engineer them and drop in at least to begin with, the australian map. It might take longer to sub in the roads etc and actually get it to take you places.
the maps are done by Zenrin for Xanavi. If it's like the Toyota ones, then it'll be in Kiwi file format, some of the Chevy guys in the US coded up some opensource decompilers/compilers that might help you. Google should be able to give you some reading material on this.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
