I'm not convinced of that eh.
I havea laurel crossmember in my silvia and the rb20 sits pretty high.
I sat a r32 crossmember next to a cefiro one the other day and they looked identical.
I didn't get the tape measure on it so I can't say 100 % but i'd be surprised to find that they are different.
if you want to lower your engine, why not just do some messurments and elongate the holes that bolt the mounts to the block?
with a Rb26 the sump sits 2-3mm fom xmember so it would achive nothing. i reckon you would only get 3-4mm with a 25.
only problem i could see with lowering the crossmeber from the chassis would be less thread in the chassis so mayby use longer bolts just the be safe, and you'd have to do somthing with the steering column connecting to the steering rack depending on how much you lowered it.
^^ That's what my tuner suggested.. I didn't the sound of it.. have you done this before with no ill effects?
screws with suspension geometry, to get a decent ride height the lower arms and steering arms have to much angle in them... the roll centre goes sub terrenial and the bump steer is not correctable even with the largest offset tie rod ends.
I had a feeling it would screw the geometry :D
Black magic and an angle grinder works wonders :wave:
a few tricks, but actual bolt in is all off the shelf wrecker parts (i just grabbed a handful of shite i thought would work and had a play). i ended up using R32 x-member and mount brackets (R33 alloy wont work nicely) i then welded in a full front lower R32 rad support and castor rod brackets etc to get the best positioning of rad etc without modding firewall... a no no in drift regs. if i had the time i would have fitted the double wishbone setup too.
rumor has it from Bai (d1 drift fame) that the laurel and cefiro x-member drops engine by 20mm.... no-one had one that i could find (but i would laugh my ass off it the one i got is :) as it was in a pile of xmembers and ther was suposed to be one in there... i just couldnt find it) so i used what i belived was R32, our 26 sits lower than other conversions though for some reason. I cannot fit much anything thicker than a paddle pop stick between x-member and sump. Absolutely Zero chance of fitting a deeper sump though as it already sits low, if it wasnt alloy i would be worried.
Thats pretty cool, got any pics ?
Like I said I have the laurel x-member in my other silvia and it sits the engine pretty high, my 26 in my silvia seems to sit no different.
Yer I tried the R33 alloy mounts and even the R33 x-member as there was rumors that sat the engine lower as well, also easier to move the engine back. That was a disaster but.
Ended up back at r32 x-member and mounts.
^^ i wll get some pics this we for you and list the exact parts i used. (via pm) i have sold the turbo kit and so forth off it so i will take pics (post here) after they are all removed it will be easier for you to see mounts etc
I like the sound of that rumour, I'll probably just get a cefiro Xmember and see how it goes.
Any idea what the actual difference (structure wise) between a Cefiro and R32 Xmember is?
The only places I need to clear are the timing belt cover (barely touching) and the cold pipe going to the throttle body. Had to lose the stock crossover pipe as the stock bov was causing the passenger side of the bonnet (at the front) to sit up about 2-3". Used my mates custom crossover pipe which has an ARC bov round the corner just before the timing belt cover, it's clashing on the bov flange causing the bonnet to sit about 5-10mm too high on the passenger side at the front.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
