APEXI FULL AUTO TIMER FOR TURBO & NA
Hey there guys after alot of time reasearching how to install turbo timers etc, i could not come up with and DIY instructions for an Apexi Full Auto timer for N/A & Turbo, i have had the timer sitting on my garage wall of parts for a while and since there was no DIY instructions anywhere for this timer on R33 i was affaid to install it. Anyhow 2 months later, i have decided to just go for it.
So, this is a tutorial for how to install a Apexi full Auto timer for N/A & Turbo.
The Apex Auto Timer allows the vehicle to idle for a preset amount of time after the ignition key has been removed. In turbocharged vehicles this prevents hot oil in the engine from coking up in the lines. Hard driving can raise engine oil temperatures to dangerously high levels. Proper cool down is essential for a healthy turbo and engine.
The Auto Timer stands as a technological marvel. The pen shaped, compact size makes the Auto Timer one of the smallest turbo timers on the market. This allows a clean and stylish installation virtually anywhere inside the car. The unique multi angle joystick button allows easy navigation through the many feature menus.
Upgraded in every way from the previous model, the new Auto Timer can automatically determine the necessary amount of after idling time. A Manual Mode allows the user to preset desired idling times from 0 sec.~10 minutes in 16 increments. By inputting O2 sensor voltage, the Timer can also display theoretical air fuel ratio. Since the Auto Timer uses the factory O2 sensor which is primarily designed for emissions, the readings may not be as accurate as racing air/fuel ratio monitors. The Timer can also display critical data such as O2 sensor voltage and Battery Voltage. To prevent potential theft while running, the handbrake safety feature shuts off the vehicle when the handbrake is released without the ignition key.
CONCEPT:
Provide turbos wind-down time
CHARACTERISTICS:
Easy to use; Simple and attractive design
!!!Caution/Achtung/Attenzione!!!
Follow this guide at your own risk. You have been warned. We are not responsible for any actions you take. The information contained here is a guide and should be acted upon with consultation from your local tuner. If you are unsure or are not confident don't do it.
Items you will need include:
- The Controll unit
- Relay Unit
- Specific wiring harness
- Double-Sided sticky tape
- Splices, binders, soldering iron, electrical tape (either of these)
- Vehicle Specific Chart
- Instruction Manual
- Flat head screw driver
- Phillips head screw driver
- Scissors
- Zip ties
- socket set (or spanner 10mm)
ON relay -
black wire = ECU ground
white wire = ECU o2 sensor
grey wire = Hand brake switch
step one
Disconnect the negative terminal off the battery (battery located in boot). [use 10mm socket or spanner] - make sure wire is kept away from terminal.
step two
Undo the bolts underneath the steering collumn [use phillips head screw driver] - think there is six bolts.
step three
Once the screws are all out keep them somewhere safe (a jar?) now gently pull apart the plastic peices surronding the steering collumn. Once these are off there should be easy access to the key clynder.
step four
Pull the harness coming from the key cylinder. (in come vehicles the whole key cylinder is a harness)
step five
Now insert the specific wiring harness. (now after many days or trying to find one, i did some research & found out that HKS specific wiring harnesses are compatible) insert the harness between the key cylinder. :)
step six
Connnect the three prong timer harness to the relay
step seven
Now you should have the specific wiring harness install with it connected to the ignition & into the relay of the turbo timer (this should not interfer with any alarm systems etc as i have one and it did not)
step eight
Use a zip tie to, connect the harness somewhere under the steering collumn area out of the way, and so it is not visible when pannel is replaced.
step nine
Feed the black and white wire behind the centre console and into the feet area of the passanger side.
step ten
Remove kick pannel on passanger side to reveal the ECU (this is in r33 not sure in other models)
step eleven
Splice the black wire from the relay into the Engine ECU ground wire [please refer to the vehicle specific ECU diagram]
" When not using the O2 sensor, A/F ratio monitor and automatic after idling functions, connect the ground wire to the chassis."
step twelve
Splice the white wire from the relay (O2 sensor signal) into the O2 sensor wire from the ECU [please refer to the vehicle specific ECU ]diagram]
step thirteen
Remove gear surround, gear knob, gear boot, to reveal 2x bolts that hold down the centre console, undo these [using phillips head screw driver] and the 2x bolts in the compartment in the centre console with the lid (they are @ the very bottom)
step forteen
Remove the center console completly to reveal the hand brake, so you can the the wire, the grey wire from the relay gets attached to the hand brake switch here.
- so from the relay you have the black wire to the engine ECU ground
- the white wire from the relay to the O2 sensor wire from the ECU
- the grey wire from the relay to the hand brake switch wire.
Now before you go any further reconnect the negative battery terminal [using 10mm socket or spanner] and turn the igniton on to make sure that: 1. the timer lights up and is functional, 2. everything on the dash is working lights etc 3. the car starts. :P
step fifteen
tidy up all the wiring using electrical tape to keep them secure and non visible, i lined mine under the carpet (for the ground and 02 wires) and through the centre console for the hand brake wire)
Conclusion
Once all is completed and functional, put back the centre console, gear surround, gear knob, gear boot, kick pannel (over the ECU), steering collumn surround and drivers side ignition pannel.
Hope this tutorial has helped people install the Apexi full auto timer for N/A & turbo as well as many other timers.
:ph34r::wave:
http://www.apexi-usa.com/pdf/productDocumentation/198.pdf
Edited by H@ME
https://www.sau.com.au/forums/topic/194842-how-to-install-apexi-turbo-timer/
Is this a full automatic timer and thus why that wire goes to ECU ground rather than a chassis ground?
Thanks for the question, yes you have the option of it being a full auto timer, which the unit will set the engine-after idle time to the ECU readings but the other function of the timer is to set your own time (as other timers allow)
You splice the black wire from the relay into the Engine ECU ground wire, however when not using the O2 sensor, A/F ratio monitor and automatic after idiling functions, you connect the ground wire connector to the chassis.
hope this has cleared up any confusion..
hame ;)
Thanks mate, the reason why I ask is that I have a full auto timer and the auto function doesnt work and I noticed yours was earthed to the ecu ground rather than the chassis so I might give that a try
thanks H@ME for the excellent post.
i have just purchased the same turbo timer from Repco and it doesnt even have a wiring diagram!
i was wondering where you got that HKS specific harness? i have an R34 and was wondering where i might be able to find one for that?
much appreciated.
much appreciated.
Hey mate i got the HSK specific harness ordered in from Auto-Barn, if you need help on installing the timer, please just PM me as i do simple jobs on carz for extra work on the side. Hame :sorcerer:
Please feel free to ask any questions you want.
  • 1 year later...
hey mate,
I've got the turbo timer installed on my Supra and can't get the auto feature to work.
I've installed it using the ground on the ECU
the o2 voltage works but the A/F just flashs with two hyphens '--'
i have one of these installed in my car
the auto function doesnt work, but that doenst realy bother me
what bothers me is that i cant lock the car with my remote when its stil running else the alarm goes off.
anyone know how to fix this>?
Interesting you say that, as my mate has one in his Evo8 and his is the same. Has to wait for it to time out before he locks it. Kinda defeats the purpose huh?
It could be a function on the alarm that needs to be adjusted. Some of them have a turbo timer feature, but it could be turned off. Find your manual. We had to turn the car on and off in a certain sequence to activate the turbo timer "allow" function.
Unfortunately it didnt work :( But im guessing that is because the timer wasnt actually connected in conjunction with the alarm? I dont know.
hello!
guys, where i can find the Specific wiring harness?? i have timer with end on 3p
depends on the brand. You'll have to find someone who sells the brand of turbo timer you have or contact the manufacturer. and if you're lucky they may still make a harness for your car. or if you're like me it's discontinued and you just have to splice everything
Body Talk
Have you ever wondered why you sometimes take an almost immediate liking to a person you have just met? Or worried about why someone you were talking to suddenly became cool and distant? The chances are that it wasn't anything that was said but something that happened: a gesture, a movement, a smile. Social scientists are now devoting considerable wow power leveling.attention to "non-verbal communication," what happens when people get together, apart from their actual conversation.
Professor Erving Goffman of the University of Pennsylvania is involved in a continuing study of the way people behave in social interaction. He feels that gestures, movements and physical closeness have meaning which the words that the people are using do not carry.
The closeness of two people when talking, movement towards and away from each other, and the amount of eye contract all reveal something about the nature of the relationship between the two individuals. We tend to be only subconsciously aware, if at all, world of warcraft gold,of the various patterns and rituals of social behavior. We expect other people to act according to the same "rules" that we do, so much so that the manners and behavior of persons from another culture can be extremely confusing.
Fox example, North Americans tend to expect more physical distance between two speakers than do Latin Americans. Consequently, when the Latin American seems to be leaning too close, the North American complains of "invasion of his space." The Latin American, on the other hand, often considers the North American to be "cold" or "distant" because he keeps a greater distance between himself and the person he is speaking to. (world of warcraft gold)
Eye contact is one way of measuring the degree of closeness of relationship between two speakers, although there are cultural variations in the meaning of eye contact. In the Middle East, for example, it is considered extremely provocative for a woman to let a man catch her eye, let alone return his gaze. Social psychologist Michael Argyle observes that there is more eye contact between people who like each other than those who are indifferent or hostile towards each other. And the longer the length of the gaze, the more likely it is that the listener is more interested in the person who is speaking, than the actual topic of conversation. Frequently looking down can indicate submissiveness or embarrassment. Looking away repeatedly may express boredom or dislike. Women tend to engage in more eye contract than men, especially when talking to other women.cd keys
But too steady eye contact can make one feel uneasy at times. Most people become uncomfortable under the intense gaze of a stare. One scientist suggests that perhaps one reason that man becomes tense under the force of a stare is in his biological ancestors: in apes, a stare signifies aggressiveness and hostility. The person who insistently fixes his eyes on our face is often more successful in arousing our dislike than impressing us with his directness and sincerity.
Similarly, the smile cannot always be interpreted as a sign of friendliness. The person who smiles almost constantly and with little apparent reason makes us uneasy. Even though he may believe that he is expressing friendliness, he may really seem nervous and tense. In other animals, bared teeth are a warning gesture, a danger sign. Aion gold
Genuine warmth or interest can be revealed in the eyes, suggests Dr. Eckhard Hess of the University of Chicago, who believes that the pupils of the eyes can indicate emotion or interest. The opened pupil tends to be associated with pleasant, satisfying experiences. That special sparkle in the lover's eyes need not be fantasy, for love may make the pupil grow larger. Sometimes when we feel that a person is "warm" or "friendly", it is possible we are reacting to a form of non-verbal communication - his opened pupils.
The next time you are at a party, take note of some of the silent messages being sent around you. Notice which persons seem to draw naturally together to speak, which others try to stay further apart or even avoid meeting each other's eyes. You may find that this silent language is much more fascinating than the actual conversation going on around you.
  • 1 month later...
  • 1 month later...
Hi.
Sorry for bumping old thread. I just got this Apexi Auto Timer second hand yesterday, and it came without manual or something related, and also without harness.
And finding vehicle specific harness from HKS or Apexi also a big problem here in Indonesia. So, any info about which cable to splice? Especially for the ignition part. Is there any cable intercepted by the timer? Or it just tapped?
Picture/photo/diagram would be very very helpful.
Thank you.
Hi.
Thank you.
Hi.
Since no one replied, so i decided to do this by hardwiring. Pretty easy stuff actually. Here's simple instruction:
timer red goes to +12V constant (white + red stripe from ign)
timer blue goes to ACC signal (blue from ign wiring)
timer green goes to ON signal (black + yellow stripe from ign wiring)
gray goes to e-brake signal
white goes to o2 sensor
black to ECU ground if white connected to O2 sensor, to chassis if white not connected anywhere
  • 2 months later...
Hello there ....i realise that this is an old threat,but i really need som help : S
i just installed a Apexi Full Auto Turbo Timer on my S13.all wires are correctly installed but i have a problem.when i turn the ignition switch off the timer starts
the countdown and when it reaches at 0 sec the timer starts all over again.so my engine wont turn off.i've tried everything i could think of.
if anyone knows the solution!!oooh also the A/F doesnt work.the red led just keeps flashing.the 02 cable is correcly installed in the ECU.
every thing is connected as it supposed to be. btw i swapped to a RB25 dont know if thath helps..
Thanks alot
  • 1 month later...
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
