i recently got my turbo hiflowed by gcg, did the whole shebang, injectors,fuel pump, pfc etc..
took it for a tune at Unique, and it turns out that i cant hold boost. they swapped over a r33 gtst actuator and added tension, and according to them, there was a slight improvement holding boost.
they also patched in a profec b ebc, and upped the gain to max, and it held boost much better.
from the graph, you can see:
on high boost, 18psi drops to ~13.2psi
on low boost, 13psi drops to 10 psi
the guys at unique cant figure it out (im sure they would eventually, but i cant afford to keep dishing out money :D)
so im looking for some insight/experiences someone might be able to share.
atm, im looking to upgrade the actuator to a hks adjustable, and also looking into putting in a avcr boost controller.(currently have a dual stage turbo xs boost cont.)
but if i can get some advice before doing that, i can spare myself some cash!!
what do you reckon??
Edited by bikey
https://www.sau.com.au/forums/topic/194853-r34-with-gcg-hiflow-problem/
The hks actuator will not provide you with anything that the profec b won't handle. Not at 18 psi anyways.
Cars i've worked on using the usual standard actuator + avcr or profeb b, etc etc all can usually easily hold 18 psi flat.
There is some other problem.
This may sound silly, but try dropping the exhaust. I.e. just run the turbo straight out into the air.
the exhaust heat is too hot... can you imagine the heat generated in the engine bay? lol plus, i dont think any workshops will let me. (ive asked a few)
btw, ive got a split dump pipe running 3 inches throught the front, cat, catback...
and yes, got a Trust FMIC happening...
Edited by bikey
Ok, another option that i've seen with some gcg highflows and other highflows - the catridge is shorter, which means that the wastegate flapper leaks. But i'm guessing that unique already checked this - when you said that they added tension (by bending the rod)
his exhaust isnt restrictive. its got a trust front pipe, hiflow cat and a 3" cat back. his exhaust flows.
its just that on the dyno whenever its given a boot, no matter if its on high boost or low boost it loses around 4psi.
i was having a read about the GCG turbos, when they weld on the wastegate they weld it on with the wrong angle so when you put your wastegate actuator on it makes the wastegate flap open slightly. thats why the extra preload (tension on the wastegate arm) would have helped.
ive got a similar problem with my gcg hiflow and ill be putting a bit of extra preload by bending the actuator arm a bit.
manwh0re, i reckon you should try this too if your turbo isnt stuffed. i remember you telling me that you used to start seeing boost at 4000rpm on your slide hiflow. it may be a similar fault.
Look at eliminating the cat as a restriction point.
$30-40 should see a 3 inch pipe with flanges welded up, and then you're not wasting workshop time and paying more $$ dropping pipes off etc.
If you do a search under a thread by Al, you will find he experienced some high flow performance issues that ended up being exhaust system related.
FWIW, the graphs themselves look quite respectable at the boost levels being achieved (namely dropping).
Joe, already did it from the start :wave:
very similar with my slide highflow
I ended up using a cheap 3rdhand GFB stealthFX plumback BOV (helped a little IMO) and awaiting my HKS heavy duty actuator from Nengun, who certainly arnt in any sort of rush to post it out to me
Im hoping the actuator will help me hold the boost better than what it was when tuned.
Is your intake the factory rubber one? perhaps its sucking closed on boost ??
And don't waste your money on fully sick boost controllers, just get yoursself a turbotech one, doesn't spike etc..
I'm using one and it holds 16PSI all day lonng
i'll put it down to the hot side being to restrictive, causing high back pressure on the manifold side of the turbo and forcing open the wastegate.
how much power do you think can be put through an op6 turbine housing, its designed for standard power, sure the highflow wheel will help, but only so far. if you want every last bit possible, get it power ported as well.
a 1 bar actuator might help a bit, but that will become your lowest possible boost setting remember.
hi bikey i had the same issue with my boost dropping at high revs on my high flow ,tuners were stumped until i saw the rubber intake pipe sucking close at high revs, read this it has solved my problem
http://www.skylinesaustralia.com/forums/Lo...87#entry3458787
Edited by OVADRV
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Good time for a carbon roof
    • Not in any way aroused by any of those, except maybe the big AMGs. And that would break my never a Euro, ever, rule.
    • You got any more detailed photos of the tow ball set up?
