Hi guys, After blowing a turbo gasket, I’m in the process of fitting 2 stock RB20 turbos to my Nissan Syline R32 GTSt. All the work is been done at a engineering firm in Bunbury WA where my dad works.
We are making 2 separate manifolds one for each turbo. Front 3 exhaust outlets to one and the back 3 to the other turbo. There is going to be a balance pipe that goes between both manifolds to equalise pressure into both turbos. We see there is no need to have 2 wastegates so one will be blocked off. All water and oil lines are been ‘T’ . There will be 3” pipes coming off the back of the turbos converging into a 4” exhaust system. Air intake for the turbos will consist on the 1 pod filter, splitting into 2 pipes after the afm then to the turbos. The outlets for the turbos will converge into one tube entering the front mount intercooler then engine.
This project is well underway, and if all goes well will be completed in a month. Before starting this project I had 200bhp running a stock turbo with 13psi, with the intercooler and a 3” exhaust. I have had it down the drag strip with a time of 13.7 @ 167km/h.
I was interested if any one had any comments on how laggy it will be, the power output I might achieve, or any concerns about what im doing. All comments will be appreciated. thanks, Ewan.
https://www.sau.com.au/forums/topic/19547-twin-turbo-r32-gtst/
I guess the major cost in this project that would be incurred is the labour involved in engineering such a setup to work properly.
Of cos thats somewhat irrelevant here since your dad works in the firm.
For the typical enthusiast out there, such a project would not economical, since the labour cost would overwhelm everything esle.
But for someone in your shoes, i guess it would be the natural thing to do, since rb20 turbos are rather cheap, as well as the rest of the parts involved.
IMHO u might need to stick to 2 wastegates to get more accurate boost control, but i may be wrong here.
Always good to have something out of the ordinary...
do keep us updated! ;)
What 1 bar barrier? He's only using 1 turbo on 3 cylinders, which means for the same pressure, the turbo is spinning only half as fast (in theory). It's not going to be 100% efficient like that of course, but each turbo will definitely be able to run more than 1 bar of boost reliably.
That is the problem, both turbos have to run up to the original speed to generate the original boost, but now there is only half the exhaust gas volume to do it.
As a result I would expect the boost threshold to be about twice the RPM it was before. You can fix it by fitting smaller a/r turbine housings, but the top end airflow should be awsome either way.
oops nice some one actually read it he was paid in food and i kicked his ass and made him piss and im a CHICK yeh thats rite na i have to be nice hes allright but needs to put his little rotor back together as it sound strange?? at times!!(n e bunno people will know what i meen )
k
ahha mike
your car is the same as mine basically
i drive mine NORMALLY i didnt buy a skyline to thrash it qtr mile it etc
im gonna make it run good and keep the boost standard and just make it look decent
im not into this "ooh ill drag u" shit
id like my car to last and not be thrashed to the max
and maurice i couldnt care less if ya could beat me
hell a LOT of cars on the road could beat me
i dont go on as my cars sumthin special
i tell ppl
its a STOCK SKYLINE
all id have to do is spend a bit of $ like ewan did on a intercooler etc and id own u like he does
but the fact of the matter is i am not interested i got the car cause i love skylines
the end
also the 20c remark was a JOKE :)
and yeah iluvewan i know what ya mean by the rotor comment
hes gotta add some cylinders and stop making it sound like a whipper snapper ;)
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
