Anyone get K.O'd by the huge dumping of rain an hour ago?
Our drainage got blocked and flooded whole garage. Was seeping under the concrete of the floor.
My room is next to the garage so my wooden floor probably going to be stuffed hehe.
We have insurance but still a hassle oh well.
Pix!
https://www.sau.com.au/forums/topic/196099-flooded/
pwned! down incline driveways FTL.... unless u have a big ass grated drain at the bottom to redirect the run off water..
I got a down incline driveway. It sucks. I just spent the last 15 minutes removing all my stock parts from the garage floor as it was starting to flood. Mine is so steep i can't park my car in there without scraping the front bar. I even have one of them big ass grated drains too :action-smiley-069:
https://www.sau.com.au/forums/topic/196099-flooded/#findComment-3510387
LOL - doesnt sound good out eastside today.
https://www.sau.com.au/forums/topic/196099-flooded/#findComment-3510420
dam.... we have a downward inclined driveway too but we have a grate and piping which stops that from happening... luckily... not that i would be too worried about my VL getting a swim... in fact i would prefer it did... its insured for more then its worth and it currently isnt running :action-smiley-069:
https://www.sau.com.au/forums/topic/196099-flooded/#findComment-3510540
Pat my bedroom is a bloody garage. i got all of my crap from 1 side to the other. emptied out a good 50L of water with a huge 10L bin....
mouldy carpet smell is awesome......
anybody complain about their garage getting flooded ill personally bitchslaps ya!
https://www.sau.com.au/forums/topic/196099-flooded/#findComment-3510706
On a serious note, if people need assistance with flood or water damage, examples are flooded garages :action-smiley-069: water in houses leaking rooves etc call the State Emergency Service (SES). 132 500. You will be directed to call 132 500 if you call 000.
https://www.sau.com.au/forums/topic/196099-flooded/#findComment-3510714
I was at work all day, anything that could have gone wrong, went wrong. We had 6 major leaks, and a tram got hit by lightning right outside! on top of that, as whithorse road was flooded there was water simply flowing in the front door... it all make for an exciting day, as none of the stuff getting damaged was mine :D
https://www.sau.com.au/forums/topic/196099-flooded/#findComment-3510754
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
