the following is free to anyone and is being thrown out at the end of the week
1 x std r33 gtst coils (misfire at 12psi on max load)
2 x front 33 gtst series 2 seats with rails
2 x rear 33 gtst rotors (need machining)
1 x carrozerria lcd tv & controller module (missing loom)
it will be thrown out on the weekend
pickup in tullamarine im not delivering anything (dont even ask)
https://www.sau.com.au/forums/topic/196271-free-to-good-home/
what do the seats look like? dibs on em if they aren't horrible looking and marked by the seed of paul. oh and i'll take th LCD tv and controller. I'll be in tulla on friday morning if that's of any help.
ok;
driver seat bolster is worn and ripped a bit - rest of seats are OK - upgraded to GTR seats
coils are ok and work fine - just misfire on 12psi - fine for stock rb25det etc
rotors are ok - need machine but no big bad marks etc
lcd tv and controller module are gone
im home tomrorow night - pick up after about 8pm is OK
im out thursday night
friday night is ok at the moment
sat night is ok (after show n shine) as i have to be home
sunday day / night is ok
Me take all the rotors!!
Phil I'll probably be in Geelong on Thurs or Fri night.. will let you know asap :P
If you wanted to drop them at Bell Park, Highton or Norlane that would also be helpful :(
Actually my brother is also in Portarlington :rofl:
you can have them, but i ain't delivering :rofl:
PM for my address.
