as the topic says, whilst removing my stock dump pipe the passenger side top bolt snapped, with the thread stuck in the turbo side. the other 5 bolts were all ok, and sprayed in wd40 beforehand but this top bolt was very brittle and snapped.
my new single piece dump/front pipe is bolted up, but i now have a big exhaust leak between the turbo and the dump, at the top because there is no bolt to hold it together. i can feel a fair amount of air leaking at idle if i put my hand there.
i've been told my turbo will have to be removed to get this broken bolt out. can anyone recommend a place where i should take it in perth, to fix this properly for good? anyone got an idea what i should be paying for this labour, so i don't get ripped? any help is appreciated.
cheers,
Chris.
https://www.sau.com.au/forums/topic/19780-help-dump-turbo-bolt-snapped/
Man - not good. Boo to rusted brittle studs!
Pulling the turbo out isn't an impossible job - Zanda and I managed it on his car ok. Once you have it out you could try what is called an "easy out". Basically you drill a pilot hole into the offending stud and bash this "easy out" thing in with a hammer and then use it to turn out the remaining thread.
If you're not confident doing that then a workshop is definitely the go but it's gonna cost a fair amount of coin because of the labour time involved.
Good luck either way man...
  • 5 years later...
i too got a broken bolt on the turbo-to-front pipe.. :(
and it wasnt evan me who broke it..
anyways i blew my turbo yesterday..
well not blew..no smoke and i can still drive...
just really really loud bearing noise...lol
i didnt get the car home, till lik 6ish..
and i started removing intake pipe, heat shield etc.. straight away...
i got the 2 top nuts off the turbo that hold it to the manifold..
and 3 that are on the side that hold the exhaust/front pipe..
but my mate decide to have ago..and he broke one..
anyways..i was thinking about drilling it out while the turbo is still in place..
would this b a good idea??
i believe i can get a drill in there..
but any ideas or tips would b great
im getting another turbo put back on so...aslong as i dont destroy the front pipe..i should b ok..
oh yeah..is there any real good removal help guide for turbos for rb25det or fitting guides that anybody knows off?
bit of a tight fit to drill
unless you have a right angle drill?
also since the turbos bust, why not just remove it?
is it possible to weld a nut onto it then remove it?
mate did with snapped studs in the head
well i got if off...
i got another topic on this,..a separate topic on..coz the main problem was the turbo was whining...
and it still is..
anyways..
i got new gaskets today..so im trying that,,,
but this turbo i fitted..a series 1 r33 turbo...
had a snap stud in the corner..lol
and ther person has tried to drill it out twice..but couldn't get it out..
its fitted to the car already..
a mate from work recons i should have drill it out completely and put a bolt and nut on it instead of just leaving it..
plus put the new gasket on with exhuast(copper colour type) sealant..thats sensor safe..
i also got told to do this by a turbo place MQT in perth..just on the bell-mouth/dump side only...
is there a easier way to get those 2 bottom nuts on the dump/turbo wen the turbo is on the car???
i had to remove the 3 dump/front pipe bolts and coz i couldn't get to the 2 nuts wen i took my turbo the first time...
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
