Hmm turns out i actually don't have fog lights either :D. I thought i did because it said so in my car manual, but i checked recently and it turns out i don't.
Anyway, i think my parking lights are T10's and i have an R33 Series 1?
  • 4 weeks later...
  • 3 weeks later...
wot about R34 xenon headlights... anyone know wot type of bulb they are??
R34 Headlight bulbs are
Parkers: T10
Low Beam: H1
High Beam: GE 9011
Note GE 9011's were discontinued about 18 months ago,they were replaced by Toshiba 9011"s but you can also use any 9005 bulb by filing a bit off one of the tabs.
Both H1 and 9005 bulbs are as cheap as chips on everyone's favourite auction site.about $18.00 a pair including postage
mate can you take a pic of the front bar indicators next time you take em out ..never seen them with fog lights in them on a series 1 before...mine just have a slot for the parkers..wouldnt mind chasing up a set..
Edited by thizzle
Parkers: T10
Low Beam: H1
High Beam: GE 9011
If you can get a hold of the 9011's use those as they are the brightest halogen bulbs you can get.
A comparison:
http://hirheadlights.com/stats.htm
And some info on 9011's
  • 3 months later...
If anyone is interested im putting together an LED kit for the R33 series 2 (maybe more models if these become popular)
Basically replacing all of the exterior bulbs with LEDs.
Fog lights
Parker lights
Front, side and rear indicators
LED indicator flasher unit (so no more fast flashing indicators)
Reverse lights
As i already have the aftermarket LED tail lights in i wont be getting LEDs for the stop lights. I did however put LED bulbs in when i had the stock tail lights in and they looked crap.
Ill post some pics in a few weeks.
  • 3 months later...
  • 4 months later...
cheers for the help ppls
i moved the washer bottle to the side, and managed to get it out, and back in, using long nose pliers.
here's my contribution to your thread :thumbsup:
the parker bulb type, and holder. R33
hey just asking how did u managed to put the new light in??? I got a series 2 R33 and it is very tough to put it back...did u twist it or something?? mine is a 15mm wedge btw...so its a big bigger
  • 1 month later...
.. And be careful even with 'so-called' white LEDs. My car had DAN-666 'white' LEDs which when I was forced through a Regency defect inspection for my exhaust, they added my 'too blue parkers' to the list of things to the *new* defect list. Awesome.
Yep for the reason shown below, something that is 'less yellow' appears 'more blue' even though it is a spectrally a definate pure white (5000k to be exact) it is 'less yellow'
than a 3000K tungsten bulb.
A good example is to put the white LED next to a BLUE one, it actually appears 'more yellow' but for the clowns at Regency 'perecption is reality'
Edited by 666DAN
  • 4 weeks later...
Hi, does anyone know if you can upgrade the globes on the Driving lights for an R33 series 2. I see from this thread they appear to be 55W H3's and I know that for the headlights (being plastic) you shouldn't go above the stock 55w bulbs, but does the same apply for thre driving lights? (are these lenses also plastic?)
They are fog lights mate. And are pretty much illegal to use in 90% of driving conditions. Which is why i put an SMD LED cluster bulb in there, so now they are driving lights.
I could argue the point to the police if i get pulled over, i probably wont win seeing how the rest of the car breaks nearly every rule in the book ;)
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
