I currently have HID bulbs as my low beam. Should i get a 2nd Set to install in the highbeam globe spot, Low beam has made a big difference. Also I know you can rig it so both lights, low and high beam, are on when you are using high beam. Would this make a huge difference? Is there anyone that has done this?
Im thinking to go with a 2nd set for my highbeams what do you all think?
https://www.sau.com.au/forums/topic/198991-dual-hids/
What im saying is no i dont want to be driving around all the time with high and low beam going. But when i switch high beam on i dont want low beam to go out is what i mean.
But my original question was will HID globes in my highbeam slots be as much of an upgrade as HID globes in my low beam slots.
https://www.sau.com.au/forums/topic/198991-dual-hids/#findComment-3550506
Having both low and high beam on at the same time while driving is probably illegal anyways..so I wouldn't bother.
WHY would it be illegal??? (If you can't back up your statement, why post your opinion in the first place)
If you were to be like the stereotypical deadshit that insists on driving around town with his or her factory "driving lights" on in your new Bogandore pissing off on-coming traffic then yes I could see it being a problem but other than that, how is it any different to running multiple beams on something like a 4WD etc, as long as you're sensible about when & where you use 'em??
Like most things, it's not the unit at fault but the application........
As for "How To", try the link below & if it all sounds a bit daunting, I might be able to help you (or anyone else for that matter) out in the New Year for the cost of parts & a 'lil on the side. Just remember one thing, you won't be able to "flash" your lights like std with all 4 beams as HID's as the globes usually take a few secs to build to full intensity etc but other than that I can't see a prob with it. My GTR will be getting this exact conversion in the near future.
PM away.....
http://www.skylinesaustralia.com/forums/Du...eam-t13979.html
While you're at it, try this DIY. Def can't hurt with the heat coming.......
http://www.skylinesaustralia.com/forums/R3...rn-t153378.html
https://www.sau.com.au/forums/topic/198991-dual-hids/#findComment-3550514
my GTR has the N1 front lights in it, the ones with low and high beam using the same bulb and driving/fog lights in the middle... If I was to fit HID's to my car, would this be a problem? (running high and low through the same bulb that is - all high beam seems to do is increase the power to the bulb)
https://www.sau.com.au/forums/topic/198991-dual-hids/#findComment-3552343
I guess the obvious problem has been forgotten...
Hid's are great, however they require time to warm up, they are not 100% until at least 10 seconds after you have flicked them on...
Secondlly, the balasts for HID's dont really like getting flicked on and off all the time as sometimes they just dont switch back on again...
https://www.sau.com.au/forums/topic/198991-dual-hids/#findComment-3554924
This is actually done either from the factory or during compliance in Vic in regard to series 3 R33's, ie. the ones with Xenons in it. I'm pretty sure my one was like that from factory but I could be wrong.
I thought it was a requirement that low beam stays on when high beam turns on if you had factory xenons, I can't imagine it been illegal in QLD, but its best to check your local laws.
Putting HID into high beam does sound like a bad idea, my high beams look yellow compared to the xenons but I don't need high beams very often.
https://www.sau.com.au/forums/topic/198991-dual-hids/#findComment-3556240
wtf!
dont listen to this guy man, he is giving u bad advice.
most ADM cars have hi beam lights and low beams on at the same time at high beam.
from memory there is a thread in the DIY/TUTORIAL section.
if not there are heaps of threads on google.
just remember low beams cut almost 10psi of fuel pressure, now having 4 bulbs on at the same time is likely to drain about 15psi of fuel pressure- watch out for that.
goodluck.
Edited by r33cruiser
https://www.sau.com.au/forums/topic/198991-dual-hids/#findComment-3556994
goodluck.
Now thats the comment that deserves the WTF...
I could right now go out to my car turn it on. Look at the fuel pressure gauge, turn the lights on, look at it again and its going to be at the same pressure.
Either way, if you aim your lights correctly you shouldn't have any day to day issues. Putting brighter lights in isnt going to solve the problem of the lights pointing to the sky, or directly in to the ground, they are still going to do that, just brighter. They will still be useless.
Anyway, moving on.
https://www.sau.com.au/forums/topic/198991-dual-hids/#findComment-3557136
My lights are aimed correctly, But See low beam only can travel so far, What i want to do is this.. HID Ballasts dont like being turned off and on again right? So i wanted to rig it so when i hit the high beams, Low beams stayed on. Get what i mean now? :D
My Second question was, WILL HID lights as high beams be much better then the halogen bulbs, Only issue is they will be turned on and off alot more then the low beams.
https://www.sau.com.au/forums/topic/198991-dual-hids/#findComment-3557202
The quick answer to your question is YES skrin3. Especially if you fit a set of 8k or 12k HID's
I have 8k HID for my Low beam and i tell you... i aint going back to Halogen EVER!! When i drive in the mountains or major highways away from the city i can see far more than ever......
There is a second option that no one has suggested and that is fitting some higher wattage halogens to your high beam. (after one has done the hi/low beam both on mod) the only issue is heat i think....
Loz
https://www.sau.com.au/forums/topic/198991-dual-hids/#findComment-3561504
Loz
Well driving at night.. Its not exactly hot so that could help right?
https://www.sau.com.au/forums/topic/198991-dual-hids/#findComment-3561948
id like to get HID's for my foglights. I wounder what bulb they are...
Mostly likely to be H3s but I'd just get the bulbs which are around $10-$30 on eBay
A HID kit for the foggies is just a waste of money and space in your engine bay.
I'm buying a few cheapos on eBay, see how they stack up to well known brands. :O
https://www.sau.com.au/forums/topic/198991-dual-hids/#findComment-3563170
not really look in the forsale section theres a guy i know who imports H3C and all other Single Beam 6500K PI hid kits for $100 brand new with invoice..
on other hand i have hid both high and low both are seperate .. when i switch high on thelow turns off.. (factory setting) never tempted to try and have both on when flicking high beam, on ..
https://www.sau.com.au/forums/topic/198991-dual-hids/#findComment-3571065
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
