HAs anyone else gone through the exercise of ringing around and getting prices on storage garages around Melb?
Im over my place looking like a car parts shed and storage place for my sisters shit for when she moved to England.
So anyone know if one place is better then another...is it worth going out of the Melb area, do they get cheaper further out of the city?
https://www.sau.com.au/forums/topic/199292-storage-in-melbourne-area/
Further out is cheaper from what ive found
But that could more have been different companies than anything
Its really hard to workout how much room you need, best to go down there and see it in person is what i found
I looked into it about 3-4 years ago... but then just ended up using a mates shed :)
I'm pretty sure Kennards has fixed pricing.
The cost isn't too bad for a smallish storage shed, my best mate was using one a little while ago, can't remember how much it was though.
I looked into car storage about a year ago now, and they charge like $200 a month :D
Storage King on Nepean Hwy behind Office Works at Moorabbin. We put all our stuff in when went to the UK for a year, not sure how much it is but we still have some bits in there. Will let you know mate :)
Fry's self storage in Bayswater is probably the cheapest in melbourne. 5.6 cubic m lock up storage for $55 a month. 11.2 cubic m for $100 a month. 16.8 cubic m for $125 a month.
http://www.frys.com.au/bayswater.html
Bris, I used kennards in oakleigh a while ago and all was good.
One thing I'd point out is insurance....if you want your stuff properly covered then I believe you have to put it under your own house and contents policy....don't take this as gospel though, just ask the questions.
lol, so this is what we've come to eh bris?
once you've put all your crap in storage, can I store some of my gear at your place? only need about 30 or 40 m2 for now, don't sweat.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
