Hey guys,
After purchasing my GTST I took it down country way and got about 400kms out of a tank, which is a 2/3rds of what I'd get out of the Suby, but it's a 6 so I spose that's acceptable??? Well after the country trip I re-filled and it looks like I'm going to get about 200kms out of tank for city driving!!!!! Is this normal guys??? I haven't been givin it heaps either, just casual city driving....
I was thinking of fitting a fuel pressure regulator, is this the fix for it????
Any help would be great.
Cheers,
Kyran.
https://www.sau.com.au/forums/topic/19996-fuel-consumption-what-the/
Nope, that's not normal.
I get around 440km to the tank (when the fuel light comes on) with city driving.
I'd check the O2 sensor. Sometimes the Jap's love to run high octane fuels that have lead in them. And the lead kills the O2 sensors :D
Drop it in for a look over and see what they say, but 200km per tank city driving isn't right.
J
Jay95R33 that is really good mileage for an R33! I consider getting to 400 on mine to be very good mileage. If I've been a leadfoot or have been in a lot of traffic I'll get up to 50 k's less than that.
95GTST, your car already has a fuel pressure regulator, and it won't really affect your economy at all if faulty. Upgrading it will only help stop leaning out, ie, if anything it will make you use more fuel! Something else is wrong, as Jay says it's probably the O2 sensor.
As for other things that will help your economy in general terms - thinner oil if your engine is in good enough condition, and higher tyre pressures (40psi or so).
i get 450km per tank consistantly, city driving. only mods are pod, and catback exhaust. i have got 480km before, and the fuel light only just came on then. i get 450km with normal driving, but not soft, giving it a thrash here and there still. havent given it a proper country/highway only run yet.
I usually get 320-360 city driving and 400-450 country driving, only mods I have are pod and 3". And I drive like a girl too, no thrashing it :D
I've had it all checked out and apparently theres nothing wrong with it and its not using too much fuel, so they say!
I get 550-560kms freeway driving at 100km/h off boost. The last 40kms the fuel light is on :D (hehehe)
Hammering it constantly (ie, a cruise) I'll get 450kms (last 40kms with light on also)
And mine throws flames out the exhaust when downshifting and accelerating being a leadfoot.
Go figure.
yes 95gtst ive been through this when i picked my 33 up i thought what the when i only got about 250-300 out of a tank. tested my o2 sencor (it was dead) so wacked one in, changed the plugs and am know getting around 400 with no fuel light around town (60%) or around 9 litres per 1oo km. havent checked it on a trip yet.
its interesting a thread like this has come up, i always get about 400Km to a tank, maybe 350km if i have been on boost a lot, this is city driving (i never country drive).
On saturday when i was at my mates trying to cut the lock wire (i still don't know what colour if anyone can help) we had a fiddle with my blow off valve. its a HKS SEQ blow off valve and we undid the screw on top another turn, now it seems to blow off much louder and more often? it sounds like it is bleeding boost while i am driving but when i look at my boost gauge it says i have vacuume. Anyway i filled it up that day and i still have about 1/3 maybe a bit more of a tank left and i have done 350Km. so i will prob get about 466km out of the tank.
i thought i would get less km out of the tank by doing this. my mate hasn't looked but he said if i have a map sensor it may save me petrol?
Originally posted by DREMEN
I get about 350 - 400km's per tank :)
Anyone know how to test the o2 sensor to see if its dead?
350-400 is completely normal, I wouldn't worry about it. Unless that's only freeway driving.
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
