  • Replies 268
hmm, looks like take2 lied to us.
Stupid thing to do, now people will import it so they get the whole game plus they'll get it cheaper.
It's not really take2's fault though. You need to speak to Michael Atkinson.
so who knows somewhere reliable that I can pre-order a special edition? or maybe I'll just keep my pre-order. then flog the game on ebay at a loss and re-buy an OS version.
I have my version on PS3 preordered and I think im gonna wait till I find out exactly whats been canned before I cancel my preorder and by and overseas version. One question though if I do decide to import the overseas version will i have trouble playing multiplayer and downloading updates etc? would I have to download the updates from which country I purchased it from?
Yeah i have bought a few games, they are very good. They have a bank account with westpac so that makes it very easy :cool:
fwiw i dont think it will be a big deal to download the updates via a us account but it would be pretty crappy if for some reason u couldnt get them
yeah looks like i f**ked up. the article slim posted says NZ will be censored too. I can't see why though. they have R18+ rating for games and it's never been censored there before, even when it was censored here. it's all pretty f**ked.
Xbox 360 pal only for us aussies
NZ and AUS censored
If you need an uncensored version theres is only one other option
UK!
http://www.game.co.uk/Xbox360/Action/Shoot...-Theft-Auto-IV/
But orders after 7th april which its 9th today cannot be guaranteed for release day.
Or you could try this, i just bought it from here. Cheap supposed to be uk pal version. Fingers crossed
http://cgi.ebay.com.au/GTA-4-GTA4-GTAIV-Gr...1QQcmdZViewItem
Edited by Pattygtst
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
