bahahaha
- double decaf short soy late, no sugar - heavy on the estrogen, light on the testosterone
You drink milk at home lol
You get outta here no one invited you
rofl I have to live with that.
It seems like Troy killed the thread.
So I am bringing it back.
After having all you broad minded persons rip on me about my soy milk.
I have cut that out and been drinking my BN with just water.
Haven’t noticed a loss in weight or gain over the past week and a half.
This could be the fact I am replacing my fat with muscle at the same rate?
a week and a half?
nothing will be noticable in a week and a half mate.
Don't micro measure.. especially in terms of weight.
If you are about looks - then go off what you see in the mirror.
if you are about strength - look back in your log for what you were lifting or failing on a month ago.
Changing from lady milk to water in your protein "suppliment" and then thinking that since your weight hasn't changed, it must mean that you are burning fat and replacing it with muscle is retardation #1.
My bad I should be giving myself a lot longer then.
It feels like I hit a plateau over the past few weeks because I havent noticed much of a change in the weights I can lift or my look.
But yeah this is probably due to me micro measuring
Definently start hitting the freeweights!
Machines have there place (like the high/low pulley cable machine) and are good to change things up, but free weights form the basis of a lot of my sessions.
Also, probably don't cut out milk all together. If you struggle with lactose intolerance maybe try that zymil milk or whatever Is that is lactose free.
You trying to start some shit here mate? Don't f**kin talk smack flamin mongrel step up!
And get a membership, I'd recommend coming to Anytime in Tuggers with me coz my gym buddy is gay and always goes late now, but that's too far for you hey?
That would require me to do it after work which I couldn't be f**ked. Might go check out fit was first next door to the hotel
Daniel, you only use machines because that all they have
Lucky you dont go to clubs with fat old hairy blokes dancing around, because your sex life would suck
You would probably just go to a different club, hey
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
