If he can bench 175kg he can bench 175kg. Why the need too put PTC and official power lifting comps above everyone/all else?
May be hard to believe, but some people do not want to be power lifters. (and I'm not just talking about weak people)
If it helps you sleep better at night, we took a vid of him doing the lift. Paused at chest level too if that makes it official. I'll see if I can get it off his phone.
Nothing makes it a competition lift if it wasn't at a competition.
But if its paused on the chest without spotters touching the bar then its an excellent gym lift :)
Whoa, everyone take a deep breath.
I ONLY commented because the OP said something about strength training an in a way insinuated his mate was stronger than PL, who compete, thats all.
I never ever competed and had zero interest in competing, so I never compare my gym lifts with those of my competing clients. It doesnt mean I never lifted those weights, but I never benched xxx after I just did 3 squats with over 200kg prior, so I cant compare
This guy is strong regardless, because to hold 175kg over your face is not done by girly boys.
He doesnt need to present a vid, no one does, like someone said he just trains for himself in the gym, just like I did.
I hope one day he, and anyone else that strong, does compete, because I hate seeing wasted talent, which he obviously has.
We had a BB do one of my novice comps recently, apparently he banches over 170kg in the gym, he weighs around 92kg.
He made a good 160kg bench press, with zero PL experience, so clearly very strong
He actually benched 170kg but got 3 red lights on his 3rd attempt
His other lifts were 220kg squat and 220kg deadlift, he always trains with wrist straps and pulls 250kg +, but he couldnt hold onto more than 220kg without them, which surprised him.
He is VERY strong and does zero strength training, he won his first IFBB BB comp
So there are very strong gym lifters out there, what most are saying its VERY different in a comp, as Michael found out
It should be harder! Less range of motion for the roll back and you pretty much have to hammer curl them too (well at least the way I do it).
Fark hammer curling them haha!
I just use my knees to flick them upto my shoulders then sorta roll back at the same time. Works for me at the moment. Be interesting to see how I go when I start doing the 40's.
Recently with the 40's I've been getting someone to hand me one of the DB's when I get into position rather than spending too much time in struggle town getting them there myself. More energy for my actual set.
I use my knees too, but when you get to 35s on a 45 degree incline, your knees can only do so much - need to involve biceps and delts just to get them into starting position!
It's worsened by me usually having come off lat pulldown / chin ups as my token pull exercise on push day = biceps already dead!
Maybe do your benching first or something to see if it makes it any easier.
I don't have the bench at 45 when I incline bench, I found it was working my shoulders more than chest so I moved it down to like 35.
I train alone, so I have become a firm believer of "if i can't get the weight into position, I probably shouldn't be lifting it..."
The reason I do 45deg is because it's smack bang between the angles of my flat bench and behind neck military press. I also have a bit of a back arch while pressing, so that gives it a little bit of a shift towards chest. Though I probably should have less of an angle, as I'm pretty front delt heavy :/
I adopt the same principle for lat muscles, where I'll do seated row (0 degrees), behind neck wide grip pulldown (90 degrees) and close/V grip pulldown in front (not really 45 degrees, but still in between).
Decided to step up my incline dumbells to 35s...getting hard to roll them into starting position!
I thought you'd be doing heavier than that. is that for a straight press or is that press twist (not sure on the real name for it)?
Re the angle, I've dropped it down a bit from 45 to lessen the strain on the front delt which I am overworking at the moment.
Edited by SRS13
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
