Its just the path that goes right around the lake, can take a couple of diff ways. Can be between 2-3 and a bit km.
Opinion need,
Protien.... carbs and fat not too much of an issue, lost 12-3kg so going to slowly put mass on.
either:
SCIVATION WHEY + XTEND COMBO which is 99
or go with dymatize elite whey 89.
both 2.26kg
jeezus krist man.. so maney misstayks in won sentance.
You better get some powder quick. otherwise each curl you do will just take a bite out of your bicep muscle.
Yer mate i rush and im first to admit im not the best at vocab. Could not get me talking in front of a crowd, many issues.
Opinion need,
either:
both 2.26kg
www.bulknutrients.com.au
Try standing naked in front of a crowd, that'll fix your public speaking phobia.
Yer i hear some good things about there products.
Jocks id be able to do, just no speaking :P I start saying something then pause lol
No jocks, completely naked.
I go the 10$ per KG at butcher of chicken breast, I do struggling to get to 220g
You actually have trouble hitting 220g of protein per day without supplementing? Not too long ago I got in trouble for exceeding 300g per day and that was with only 1 25g serving of powder most of the time lol
This.
Stop subliminally bragging :P
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
