how does everyone keep track of their workouts?
I use the Jefit app on my phone, keeps track of all my logs and lifts, can add notes if I feel the need and has made it easy to keep track of my workout volume.
Simple notepad file on tablet.
I run endomondo also to keep track of time spent and rest periods and check email, facebook during breaks and sometimes youtube clips on form.
I'm at home though so using a tablet to play my music and record notes doesn't seem as nerdy when you are flying solo.
Deadlift 220kg Birds. In your next deadlift session.. Do it once at least & receive a virtual high five.
You will do it ha ha...
No seriously lift 220.... I am confident you can do it.
Hahaha. Right now I'm confident I could get 200 up; I don't want to try it though, cause my form will be terrible. I'm currently fixing my form with more volume at lower weights for now, as my lower back was getting a bit sore with my "yanking" as Markos calls it.
Also want my squats to catch up, because they are far behind my deads at the moment. But soon I'll return to the deadlift 1RMs and I'll definitely give 220 a crack! Tough ask for a tall skinny 80kg not going to PTC :P
I used to have just a generic diary and would scribble shit down in there, but now I just use a very basic notepad app on my phone. Only really need like 2 weeks of notes at any time to skim back through anyway.
Lunges are the worst torture known to man. I'm properly struggling to stand...squats never did this to me!
They just have this ability to extend the set beyond physical pain and it becomes all about how much you can put up with mentally.
Yea walking lunges say.....for a about 20-30 meters with lots of weight on a barbell on your back is the worst kind of pain especially after the half way mark where you just want to give up because of the intense burn. Not to mention the nice cardio workout that comes with it. I do them twice a week and have developed excellent shape as a result. Squats had sliced my lower back in two so utter fail for me :(
Eating peanut butter
This. lol. And incline leg press (plate loaded). Got up to 360kg for my working sets, so at least I wasn't being a bitch on the thing.
Looks like my ROM issue through my shoulders wasn't quite as bad as I thought, since it was pointed out I had the bar way too low anyway haha...so now that I'm resting it in a more appropriate position as well as stretching my chest/shoulders/etc beforehand, I can do barbell squats again.....my traps are f**king obliterated though, not used to having weight resting on them >.< will get used to that though.
Best part is 100kg feels like nothing! (inb4 that asshat Markos pointing out 100kg IS nothing :P). Should be back up to a more appropriate weight in no time. Will increase 5-10kg for the next couple of sessions, then 2.5kg every session without fail from then on.
Markos, I remember you saying not long ago that nothing you see amazes you anymore. I'm curious: what's the most impressive or amazing thing you've ever seen with regard to lifting?
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
