Haven't ever really bothered for anything beyond the first exercise, really good stretch first then some light reps of whatever the first exercise is then by the time I'm done on that I'm usually already warmed up or things get warm from racking weights etc.
Work through the motion itself without weight first, it's not hard. If you can do it without weight you can probably do it with. If you can't do it without weight you likely can't do it with.
I actually find it harder to do the proper motion without weight haha....though it's leg day for me today, definitely going to give just squatting for a minute a go before I get into it.
ye old TTT said that in the past
If you can't do it without weight, your mobility sucks harder than a hoover.
Yes it's easier to stabilise the body with added weight that you can move around; circus acrobats use a bar on the tightropes. But you shouldn't have to depend on it to do the movement, else you probably have stability/form issues in the movement when using weight too.
Anyone watch Olympia? Heath won followed by Kai.
Felt sorry for Kai he looked shattered
Cutler made top 10 but not final 3, Wolf took third place
Edited by -FIGJAM-
Yeah I didn't pit Cuttler woth much of a chance.
Personally hoping Kai would take ot away but of of the top 3 I thought Wolf had the best bod of the lot.
No idea how the judges determine the winner of these events
No idea how much money the judges ask for from sponsors to determine the winner of these events
fyp brah
Squatting question as I've been thinking about what I may have been doing wrong previously to aggravate my back/leg.
In the lowest point of the motion, I notice my butt will tuck under a little which implies some rounding in the lower back, is that allowed/a problem/should be avoided etc?
Or should I only go as low as I can before my butt wants to roll/tuck under?
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
