You realise leesh is female, right?
I do indeed, just thought that was shorter than average.
FWIW I was 62kg at 189cm lol
Damn haha makes me feel like more of a fat prick, measured the other day and I'm a couple cm taller than that Edited by r31slpr
Took my supps for the first time in a month yesterday; look like I'm preggers this morning. I wonder if I'm overdoing it on the creatine, though only consuming 3.45g during the day and half of that at night. Anyone else here take creatine? How much do you consume per day?
I was only adding one spoonful, so I'd say 5g tops, in my post workout. None on any other day.
I ran out a week or two ago,m haven't replaced it and haven't noticed much if any difference but I am not training heavy with weight or volume.
I always thought it best to take it straight after a workout l33sh and directions say 1 serving per day ( 5 grams )
The BN website says to take it before training, that's why I've been taking it during the day.
Odd, every thing I've read any where say's it's a recovery supp and to take it afterwards.
I've been wrong before and I don't see that trend stopping any time soon.
Edited by ActionDan
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
