did front squats today - with the clean grip I was doing it wrong cause it was loading up my wrists, was much more manageable with arms crossed, but I think I might have had the bar sitting too far forward on the delts. Did manage to get 5x100 out though.
Wow that's alright!
What do you guys think about dynamic effort and max effort body programs? I've been suggested a new program.
Here is a copy of the program, I would have to take out shoulder press and delt cable pulls due to my injury though. Please let me know your thoughts, thank you.
Monday – Dynamic Effort Upper Body – Focus on speed not weight
Flat Bench Press – 8 sets x 3 reps @ 55%– Focus on speed not weight
Decline Bench Press – 8 sets x 3 reps @ 55% – Focus on speed not weight
TricepsPressdown – 3 sets x 12 reps
Seated Shoulder Press – 4 sets x 10 reps
Dumbbell Side Lateral Raises superset into Front Raises – 3 sets x 10 reps
LatPulldown – 4 sets x 10 reps
Rear Delt Cable Pulls – 3 sets x 12 reps
Wednesday – Max Effort Lower Body – Squat or Deadlift
Max Effort Exercise (Box Squat or Deadlift) – Work up to 90% and do 3 sets x 2 reps
Seated Leg Extension – 5 sets x 5 reps
Straight Leg Deadlift – 4 sets x 5 reps
Glute Ham Raise – 4 sets x as many as possible
Front Squats – 3 sets x 5 reps
Abs/Core Work
Friday – Max Effort Upper Body
Flat Bench Press – Work up to 90% and do 3 sets x 2 reps
Incline Bench Press – 5 sets x 5 reps
BodyoverTricepPressdown – 4 sets x 5 reps
French Press – 4 sets x 5 reps
Seated Shoulder Press – 4 sets x 5 reps
Bent over Barbell Row – 4 sets x 5 reps
T-Bar Row – 4 sets x 5 reps
Saturday – Dynamic Effort Lower Body – Squatand Deadlift
Box Squat – 8 sets x 3 reps – Focus on speed not weight
Deadlift - 8 sets x 3 reps – Focus on speed not weight
Good Mornings – 3 sets x 12 reps
Seated Leg Extension – 3 sets x 12 reps
Glute Ham Raise – 2 sets x as many as possible
Abs/Core Work
Edited by L33SH
I'm assuming that's 55% of your 1RM, which you'd have a loose idea of.
I like my exercise to be very simple so to me that's a bit too involved.
I'm also not keen on splits where if you miss one day for whatever reason you miss that work for a week - but I realise splitting allows greater targeting and emphasis which is great for those with a specific goal.
I'd have a thought a full body workout x times a week would be fine for you Leesh, as you seem to want general fitness, well being, and some nice aesthetics. OR are you now looking to be a fitness model or something?
Mitch beat me too it, just times anything you need by the percentage number with a decimal in front of it.
That chick is too muscular IMO, but if that's your goal then a split routine will likely be a must, as will excellent diet.
You can do it!
Thats your speed day and your meant to be moving the weight explosively to train the muscle fibres and neural system, its not to try and build muscle.
Do a bit of background reading on louie simmons westside method and itll help explain the ideas behind each day
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
