ahaha TTT stfu
Leesh I assume when they say focus on rep time, they want it to go slow? if that's the case it will be difficult. I'll also go ahead and assume that they are going to go up in % of how much you are lifting each session or week increasing the weight and difficulty.
what?
you think that chick got like that by being a vegetarian?
you can't get the nutrients and protein you need to build muscle (especially as a female) if you don't eat meat.
Doesn't matter what routine you do.
sorry but it's the truth.
I'm not even going to go in to being given a westside style template...
That chick is too muscular IMO, but if that's your goal then a split routine will likely be a must, as will excellent diet.
You can do it!
And some *supplements*
I am not arguing your point. There is no point in harping on about her being a veggo, that is her lifestyle choice
Could make similar arguments about using roids in regards to what it does to health.
But it's not the same opinion we have so we should definitely point it out every chance we get.
We need to make sure she knows, I don't think she knows yet...
Bit of a bro-science question, but I had gastro (nasty shit.... literally) over the weekend and couldn't stomach anything so basically had nothing to eat or drink for 2 days (threw everything up bsically, even protein shakes haha) so obviously didn't meet my macros or micros. How much muscle loss can occur in the timeframe?
Could be placebo, but I THINK I look smaller and have lost muscle mass but not sure if I just loss fat or water retention.
Ideas?
I'd say most will be water weight.
Get into the Hydralyte etc, more for hydration than how you look.
When I had it a few months back I got stuck into Hydralyte and eating plains carbs etc that I could stomach and put the weight back on pretty quickly (about 3kg).
Edited by ActionDan
That's what I'm hoping for, as I dropped from 95.3kg to 93.1kg. Obviously didn't get my creatine for the weekend either so shattered about that.
Will def take some hydralite, thanks bud ;)
That's just over a 2% drop, I wouldn't stress about it unless you're trying to make a weight class for something?
Many people fluctuate that much daily between morning and night.
Nah, not fitting a weight class. Just concerned and thought all gains were lost haha
If you've only gained 2% you have work to do my friend :D
As a former numbers man, I understand the stress.
Hahaha no, I'd be shattered if I only gained 2kg. More so a figure of speech when I say "all gains have been lost".
Started 75kg @ 12%bf, now 93kg @ 13%bf.
Hoping to be mission complete when I reach 10%bf and hovering around the 85-90kg.
what?
I was purely asking for thoughts on the program, not my lifestyle choices. I respect that you all love to eat meat, can you respect that I choose not to eat meat? I hardly go on about it or mention it... you do that for me. Yes, I am aware that I would gain more muscle definition if I ate meat, but I don't and I'm not going to, so let's move on from that. Google vegetarian athletes and olympians... these althletes demonstrate that you can achieve solid muscle definition on a vegetarian diet. I just want focus on my exercise though. I can manage my diet.
Edited by L33SH
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
