Do you warm up and mobility your wrist joints, I'm getting a little bit long in the tooth now and if I don't warm up everything I get pain everywhere, LOL :(
And as we are coming into colder weather warm ups and mobility are even more important to keep injuries at bay.
You guys may benefit from taking a week to two weeks off.
Muscle I'm guessing heals quicker than cartilage and inflamed joints; you may feel a lot better after a decent break. I think it's good for the muscles too, to have an extended period of rest every now and then, particularly if you're lifting heavy most of the time.
When I get sick and this forces me to stop gym for a week or two, I almost always come back stronger (eventually) after that annoyingly long period of making your way back. I'm pretty sure that's because everything has been well rested and properly healed. Probably a good idea to do mobility stretches in the second week too.
I had 2 weeks holiday and only gym'ed 3 times in that period. Then after coming back, and getting sick, I had another full week off.
The cold affects me much more in that regard these days. I'm on the comeback trail at the moment, Monday felt good but last night was really weak, though by the time I got into the gym room it was 8:45 so energy levels were not stellar lol
That parenting life.
Yeah I mean 2 weeks without gym...nothing, nada. And gorge on food. That's 14 days of solid recovery with the fuel to do it. You might come back a tad weaker but your body will love you for it!
Of course there's nothing you can really do about old tired joints or degeneration :(
underhand grip doing rows puts the wrists in a bent back position.
and using a straight bar means they are bent back and twisted out. Then from there they get pulled upwards by the arms, and downwards by gravity.
Use double overhand grip.
either thumb under or over to see what works best.
my left wrist is f**ked as well, had a month off while I was on holidays still coming back every session eventually gets too painful and have to stop certain movements
starting to strap it before workouts.. see how that goes :\
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
