underhand grip doing rows puts the wrists in a bent back position.
and using a straight bar means they are bent back and twisted out. Then from there they get pulled upwards by the arms, and downwards by gravity.
Use double overhand grip.
either thumb under or over to see what works best.
cheers, makes sense as to what the issue could be.
Bought commercial cable cross over for $100, a second corner cross over unit for a friend of mine for $180, laying down back row for $90, commercial peck deck for $20 (that's right, $20) and a commercial ab crunch machine for a friend for $20. If I had more space, or had known that it was going to be that cheap, would have organised some storage space and bought a lot more. couldn't believe the prices. will post pics tomorrow once I have it either in the work bay or hopefully at home. the $100 is missing the cables that go with it, so will have to source them somewhere, but that's easy enough.
Having seen your dumbell racks I'm guessing you'll be charging membership fees for your garage soon...
I wish I had seen this auction before I bought all my gear. Would have saved thousands
Full commercial power rack went for $180. It was ridiculous.
Worst marketed auction ever. I only saw it on gumtree and decided to pop in see what was there. There were about 30 people there, and they were all looking to privately buy equipment for their homes.
A lot of the gear was very badly presented as well, covered in dust and some of it in mould, with scratches here and there, but it was still fully functional.
I will post pics by end of the week once I get it all home and cleaned up and assembled.
I think I get away with no wrist issues due to using bitch gloves that wrap around and support the wrist a little.
Just buy a proper pair of wrist wraps from the likes of Inzer or Titan and wrap them properly before a set.
If there is still pain you might need some fascia release or treatment on the muscles or tendons.
finally, a pic appears.
going to have to move the tv cabinet thingy and fan out and put the pec dec there and will wall mount the tv above the dumbbell rack.
have sold the calgym chest press, and am now already a few hundred ahead of what I paid for all the gear. wish I had bought more....
  • Like 1
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
