Anyone got any idea for a workout that can be completed in 45minutes or less consistently? I am pressed for time these days due to work and now training during my lunch break.
I am thinking a split system and can go 4 days a week.
Goals are obviously looks but also some strength would be nice as it would transition for sport
Would really like the main lifts squats, bench and deads in the routine as well as chin ups and either dips or machine dips
Squat, front squat, deficit SLDL
Bench, DB flat bench, weighted dips
Deadlift, BB rows, GHR
Military, DB incline, weighted chins
You've described my workout there, which is less than 45 minutes and 4 times a week...
Squats/Pullups one day
Deadlifts/Bench the next
In that order. Repeat later in the week.
I find there is little overlap unless I really push squats hard and my back is tired from them. Even then, not a big deal. I would put your dips on the bench day.
Give it a shot and see what you think?
what about shoulder development?
Mr FIGJAM
My 2 cents
Starting Strength, 5 x 5, 5-3-1 or 8-6-3
www.blackironbeast.com has some good programs.
Main lifts are Mil press, deads, bench and squats, you can do a basic workout which takes 20 minutes, lots of options with all the hard calcs done for you.
Im doing a 5-3-1 body building template which takes between 45 minutes and 1 hr dependant on rest time and lifts done.
The TRIUMVIRATE (smart mans program) should see you out of the gym in under 45 minutes
As for looks and strength you can have both with just lifting heavy on the basics with minimal assistance exercises, (i.e no bro curls or wrist curls or other stupid exercises that support the vain)
Bench will give you plenty of it
If you have to do a vertical shoulder exercise then I would say a bit of military press on the squats day.
But yes, aesthetically bench will develop them fine...and strength wise...well if you're trying to get a decent bench then bench is good for that :P
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
