I now wear stretchy material / loose running shorts, which finish a few inches above the knees. When you're a tall guy with long legs this makes you look like leg day is a once a year occurrence for you, but the range of motion is awesome and uninhibited - might as well be squatting naked.
Thinking I'll have to find something above the knees too, my legs aren't skinny though so shouldn't look to bad
I grabbed some UMBRO soccer shorts which work well for squats/everything, for footwear I use Chuck Taylors and soccer socks for deads to stop the blood if I hit my shins.
I do tuck some of my shorts into my undies to shorten then up a bit when I'm doing front squats as I find it more comfortable.
I'm not a fan of compression gear for lifting, it makes my junk all tucked up and uncomfortable.
No offense to any geared lifters out there but the gear they use makes me LOL and think WTF.
I have legit never had a pre-workout of any kind unless bcaas fit in that category.
I dont even drink coffee so I feel like I could probably benefit from something but ive never really felt the need honestly. All the ones that had good rep are banned now arent they?
fk ur pre workout
Just listen to your fav pumping music and go make that gym wish it were never born
  • Like 1
Bulk Nutrients NO3X. Give it a shot if you want, I find it quite decent and I have a small tolerance to caffeine/stims now (not as bad as I used to, but now I restrict my caffeine intake and basically never use pre-trainer either)
Also Dan, I might partly go back on my words from yesterday regarding MACA. I downed a heaped teaspoon on an empty stomach yesterday morning before heading to the gym, and by the time I got there (maybe 20 mins later) I was feeling a lot more awake and motivated than usual. Could be down to anything, so just went with it.
However this morning I figured I'd repeat the teaspoon on an empty stomach, and again shortly afterwards I feel better than usual. Particularly so after I've had a coffee.
It may very well have noticeable effect when you give it a chance by cutting out other variables haha (empty stomach), so I'll keep doing this teaspoon of MACA before I leave each morning to see if it continues :)
Still sceptical though :P
fk ur pre workout
I must say since i have ditched coffee and pre work out i have been sleeping and feeling a lot better. A lot more solid sleep too. I was previously taking a few different prescription sleepers. I had a lot of trouble sleeping. It took about two weeks after i stopped them to notice a better sleeping pattern. Much much easier to eat as well.
I have never been into PWO, tried craze once for a laugh and couldn't get to sleep until very late.
TBH, the DAA test interested more from a libido POV, but better sleep fixed that.
The maca powder interests me in terms of focus throughout the working day.
Have you had blood tests get a full hormone panel done.
Small dose of test can do wonders for all the things you mentioned and if you have low test its prescribed and covered by medicare :)
No the "issue" wasn't that serious, just a decline in my interest levels, it;s been almost 8yrs though and we'd had a pretty full wind up towards the end of 2014. As you might recall I was also getting sick quite often etc. Ella has finally stopped catching every disease and bringing it home, I'm making sure I get enough sleep, taking a multi again, making sure I get some good greek yoghurt in (probiotics) etc so I'm feeling better and have had more "interest" as a result.
I have a tendency to play down/disregard the effects of work related stress also as that's not exactly manly when I work in an office all day, but the reality is it does actually seem to take a toll on me over time. There was/is some big things happening here - good things, but lots of work regardless.
Know exactly what you mean!
I am going through much the same gym is about the only thing keeping me focused at the moment.
I don't mind pre-work out
Gets you in the mood if your not, and sometimes makes you feel like an energiser bunny in the gym
what numbers are you aiming for at the comp?
Semi related, what pants are you guys and girls squatting in? I just had a massive blow out
not sure what numbers for the comp as it's my first, I'll open with something like 190 sq, 170 dead, 100 bench and go up. General consensus is to start with something you can do for 3. I wear stretchy shorts that end midway up the thigh. Had several blowouts with other types of shorts due to my low squatting, these are basically untearable. Got them from Big W (though they no longer appear to sell them).
Good numbers. Wish i could squat as much as i could dead or better. I can get 200kg out on a dead somes days for 2 reps. Squat 140kg for 1 or two going full depth. Even thats a struggle.
Decided to get a bit more serious and start getting organised and planning meals for the week.
Hopefully it helps. Will do some more meals up tonight and freeze a whole bunch, so I have healthy meal options at my fingertips.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
