I was a skeptic until we took our previous 11yr old Boxer to see one, she was very clearly in less pain and happier. She made it to 12.
I realise you are not a dog, but I was very surprised.
hahaha im more of a mule then a dog
Got to keep on keeping on.
Some good news my way is that my groin pulled up better then i expected this morning.
No pain at all but still a little stiff
Stiff, groin...haha Edited by L33SH
  • Like 2
What protein powders is everyone using?
Looking to make a switch for some nicer/different tasting protein after years of on bulk nutrients.
Bulk nutrients is about $30/kg for WPC (~80% protein) or $35/kg for WPI (~90% protein)
Looking for something maybe similair value wise
Optimum nutrition gold standard whey was very popular at my powerlifting gym. Probably the best tasting protein shake I've ever had. A kg bag is about $60 though.
My sister loves species nutrition isolyze, haven't tried it myself though.
anyone know any bulk protein suppliers in australia?
i want to get back into taking protein shakes, diet, etc
and i've used Protein Authority a while ago after going through tonnes of US branded things (ON, Dymatize blah blah) but they've been taken forever to restock their WPIs which test phenomenal, especially the Iced Mocha flavour, beats every protein i've ever used hands down
so yeah, suggestions?
Bulk Nutrients
Just drink the protein faggots, are you downing it for a soy latte substitute or for the gains
People used to drink raw eggs ffs
people still do drink raw eggs.
i used to when i boxed. Old school gym advice
Drink it quick or put in some cinnamon in it, cinnamon is a excellent spice with lots of health benefits.
I blend 1/2 tsp. cinnamon, 30 g LSA and 30 g vanilla protein on my weetbix in the morning, YUM.
BN coffee, mocha and choc mint taste like blahhh IMO.
Chocolate and vanilla are good to go though.
I'm hearing ya re: changing off BN for a while - after I blasted through 5kg of banana WPI, BN was the last thing I wanted. 2kg of super sweet ON Gold Standard later, and I'm switching back to the cheaper blend they have out.
Some of us consume 3 shakes a day for our 3 hour arm workouts fyi Birds
  • Like 1
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
