That's badass jangles. Man, I was (kinda) close to 300 a while back ago and now am working my way up again. I am to see an ortho this 24th so I hope to get some answers for my right shoulder. I want that 300, dammit.
Always on the quest for more, with all my lifts.
As far as injuries go, I used to be hurting my shoulders and pecs quite often, now I'm at a more suitable weight for my height, the range of motion isn't as far, no more injuries/shoulder issues!
Hit 352 8weeks ago, put on about 5kg of size over last 12months so my levers are far better, plus whatever muscle for strength too.
160kg is a good bench. You mentioned you have dropped the range of motion to look after the shoulders. So is that down to the sternum and back up or just what you are handling for 1RM for the normal movement you are now doing?
either way a good weight . Well done.
Edited by rev210
I arch my back as per a powerlifting movement, it was a paused bench, in my first real comp.
Range of motion has shortened simply because I'm bigger, as I'm now around 95kg instead of 75-85kg when I was getting shoulder pain more frequently. 135kg was best paused at that bw.
Mind you, I'm generally just a lot stronger now though as my size per height is more optimal, albeit, I'm not as lean/skinny as I used to be.
Question for the diet experts (déjà vu is telling me I've asked this before):
I had an all vegetarian meal lastnight, with a lot of mock meat in it.
Now this mock meat is, from what I gather, usually made from wheat gluten / seitan, which according to google is upwards of 75% protein, 14% carbs and 2% fat.
So aside from coeliac sufferers and the seemingly growing trend of gluten intolerant people, why isn't this considered a superfood / eaten by bodybuilders and people in general looking for heavy doses of protein?
The concenstration of protein is nearly 5 times that of most lean meats, so why aren't we all downing this regularly? It's not expensive and tastes pretty good, what downside am I not seeing? Is it a case of not all proteins being alike?
Many of the greens like broccoli have a far greater % of protein than meat too, it's just you need so much of it.
It's the exact reason why it's far better to use grams per 100g than a percentage.post-49273-0-47091900-1439179733_thumb.jpgpost-49273-0-47091900-1439179733_thumb.jpg
It's the exact reason why it's far better to use grams per 100g than a percentage. 31 Responses to Plant Protein_ Why Vegan Diets Need Beans.jpg 31 Responses to Plant Protein_ Why Vegan Diets Need Beans.jpg
Sorry I should have used grams instead of percentage...it's actually 75 grams protein per 100 gram serve. Given gluten is itself a protein, it doesn't surprise me that this is so high - it would be like making food out of protein powder. But what confuses me is why it's never talked about as a go to source of protein - there has to be something incomplete about it.
P.S. the mock duck is really quite close to the real thing. It's not perfect but it's enough to make you say wtf
oh for shame birds.. for shame...
the shit we do for pussy hey?
Pfft that only counts if you weren't getting the vagina beforehand
Believe it or not this was my idea
I think it's a pretty good test if you're gluten intolerant too...
That's interesting, as Soy/Tofu protein per 100g is less than lean meats
I don't know much about vegetarian foods, but I don't think this is soy/tofu...it's technically made from wheat if it's mostly gluten. Don't think this would be so different from the protein you find in wheat flour based breads etc. just in more concentrated form. The sweet and sour mock pork actually tasted like a slightly salty corn bread texture.
Also western mock meats tend to be soy/tofu based like tofu burgers and soy sausages - this seems to be largely an Asian cuisine.
From my quick googling there is no abundance of information on bodybuilding / supplement discussion forums or websites about mock meats and seitan, only vegetarian websites pointing vegetarians towards good meat alternative sources of protein.
Even Seitan is only on par with lean meats per 100g, which is generally the highest protein content.
You'd probably find more info if you googled vegan body builders.
But then again, bros don't like carbs and salt.
I wouldn't trade it for meat, unless it was considerably cheaper as a sometimes substitute.
Is that 100gm with the water content taken out?
Most lean meats are around 20gm P /100gm aren't they?
Some of the vegan bodybuilding forums have talked about it but nothing scientific or conclusive. One or two people commented on bioavailability being poor, i.e. for all the protein to be absorbed you really need to balance it with other proteins.
A lot of them supplemented their diet regularly with it though.
I wouldn't give up meat for it but it's interesting that there's something versatile you could get easily and tastes good. That mock meat really was good.
  • Like 1
Not sure,
But cooked lean meats are closer to 30g/100
  • 4 weeks later...
    • So the original radiator is leaking now. Looking at getting a fully aluminium one next. Am I correct in saying that the Series 2 Auto Stageas have a separate trans cooler from factory (located in between the rad and intercooler in my previous post/message).   Currently looking at Fenix $460, Blitz $700, GReddy $800, and KoyoRad $740. What are everyones thought on Fenix ( ive read a few comments saying theyre cheap Chinese rebrands etc and how their build quality is... well.. chinese...)  compared to the others? Worth the extra couple hundies?
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
