  • Replies 100
There's always the cafe: not quite as much fun, but has a really good section of veranda around the corner, with plenty of seating, so it will more than suffice!
If we're doing the bbq thing, do you guys want to put in, and I'll get some sausages, bread, onions etc?? Or would you prefer to do your own?
This is assuming the weather is going to be ok: bom says it looks good so far...
well done micah, we all should bring a eskie and if the weather is shittie just drink the beers and take the burgers home(forecast seems ok????), and if the weather is crap we could hole up at the numinbah correctional centre i'm sure they would make us welcome and find our cars interesting
ps think i might try and meet up at Advancetown' will ring you on the day.
Yeah... I thought the correctional facility entrance would be a great photo opportunity!
leetom: ignore the pm I just sent: must have written it while you were posting here (typical!).
Ok, here goes: I will edit as required, but those who have shown interest are:
ARGH-ESS '97 RSFOUR
IIJI S2 RSV
RUBBA '97 RSFOUR
BERNARDSHORTY '97 S1
PIXEL8R '99 RSFOUR
OLDIE '98 RSFOUR
LEETOM S1 RS FOUR
CHOOK '00 RS FOUR
66YOSTAGEA '96RS FOUR
STAGE1 '97 STAGEA
DARRINSPENCER S2 'TYPE-R'
WHOOBY S-TUNE
STAGECOACH CROTCH ROCKET
SLEEPYNIGHT 260RS
GREENGHOST RS2
ANTONY
RB26STAGEA '97 RS FOUR
So.....
I will update as needed, but as it stands, anything more than 50% attendance will make this the largest Qld gathering so far... The more the merrier, people: let's make this a big one!
Negative.... teh crotch rocket has been sold to pay for my compliancing. Will be a no show.
Any other veggie guys coming? If not, I'll flick the fake flesh and pack my own! I just need a packet of chips and a soft drink as I am hoping to listen, talk and learn lots!
I'll be bringing my old Apexi rear muffler of my R33 if anyone just want to spice up their exhaust sound without too much more noizzz! Worth a bit but I'm thinking about $120 would convince me to part with it! It's a big barrel with standard in and 5" out tip. Simple and solid-looking!
i i j j
HI
I will be on my one so I will probably grab something from the BP and take it with me.
I don’t know if any others are interested in the BBQ but I will still put in if this helps
As far as the weather is concerned I am going to take sunscreen and a hat. That’ll chase the rain away
Cheers
phil
1 more sleep :thumbsup:
I assume we're not all putting in for a sausage sizzle. Catch you guys at Coomera: this should be good: hopefully the weather stays fine (but cooler than today!).
I'll be there but the Stag will be DIRTY.
The time I allocated for cleaning was completely fu^^t up because of power outages. We are on rainwater and pumps, so no powa no wash
I'll just spray a bit of underarm and be sweet as a nut.LOL
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
