Hi guys,
this is my first post so forgive me if its in the wrong section. I've recently purchased a Fully stock 93 R32 GTR and wondered what sort of oil pressure i should expect as it seems a little low, also the car is pretty sluggish and unresponsive until it reaches higher revs before it warms up, is this normal? Apart from this it drives like a dream, no obvious issues elsewhere, are the problems related? When the engine starts it'll sit about the 2-3 (out of a max of 8) mark but settles lower after a few mins!
Any feedback is appreciated!
Thanks!
https://www.sau.com.au/forums/topic/202418-oil-pressure/
Yeah a lot of the oil senders are broken with time
Worry when the red light comes on
In the meantime you can get a mechanical guage hooked up for peace of mind
Keep the revs down (and dont use heaps of throtle) before the oil gets to the first notch on the middle dials
:blink:
https://www.sau.com.au/forums/topic/202418-oil-pressure/#findComment-3594214
The reason the car will feel sluggish is the ECU dragging ignition advance out of the engine when it is cold. It is trying to tell you not to hammer the poor thing until it gets warm!
Replacing the sender unit is neither hard, nor particularly expensive. Order a new one up from Nissan & install it on your next oil change. $200 should see you right. From expereince it doesn't matter how many times you tell yourself not to worry about the pressure you still cant get it out of your head. :blink:
https://www.sau.com.au/forums/topic/202418-oil-pressure/#findComment-3594225
Replacing the sender unit is neither hard, nor particularly expensive. Order a new one up from Nissan & install it on your next oil change. $200 should see you right. From expereince it doesn't matter how many times you tell yourself not to worry about the pressure you still cant get it out of your head. :D
My mechanic says that when cold, the gauge will reflect twice the relative value of engine rev. aka 2k rev = 4k oil pressure, 4k rev= 8k pressure... oil pressure being kilogram per cm^2. aka 4kg per centimetre ^2 = normal for 2000 revs.... course, this depends totally on ur oil, the gauge and the position of the sensor. seriously if u got a gauge like that, it means stuff all without taking into consideration the oil, the oil temp and how old the oil is, how much you've warmed yr baby up etc....
And engines aint engines... cars always feel sluggish for at least 10 minutes as the ECU purposely restricts the ratio. even when u floor the accelerator, the ecu will limit the fuel/air... thats its job.course u can override it, but is it wise? Best to let it at least warm up for 15 mins before even cranking it over 6k. Thats my opinion anyhow, tho im no mechanic. But im superstitious and sometimes when I fang the car and nurse it, it comes to me, it comes to me in my dreams and says "Oh u PIMP, i LOVE u, pls for to be pimpin me some more"
And so I do :blink:
-D
https://www.sau.com.au/forums/topic/202418-oil-pressure/#findComment-3595282
THIS IS A HUGE ISSUE hope i diddnt miss read ur post but hell man i just bought my gtr a couple months back i start it let it sit for 5 minutes before i budge it then i keep it under three for the next 10 minutes.... call me over careful but these engines cos a bit to fix when mistreated! most damage caused to all engines is when its cold let alone turbo ones so baby it untill oil and water hits running temp. and always puppy it before u get home and let it idle down for a couple minutes when u get home. owning a gtr is a big responsability especially one as old as an r32.
as far as your question my oil pressure guage reads similar.
good luck and safe driving
https://www.sau.com.au/forums/topic/202418-oil-pressure/#findComment-3595324
This is THE WORST treatment for a modern engine. Excess fuel thins the oil, washes oil from the cylinder walls. The spark plugs run cold and carbon up.
Just fire it up and get moving ... GENTLY (under 3k), until the engine shows a reasonable temp on the gauge.
https://www.sau.com.au/forums/topic/202418-oil-pressure/#findComment-3595484
  • 4 weeks later...
It may also depend on the type, grade, quality and age of the oil being used.
I just did an oil change to Mobil1 5W-50 SuperSyn. Cold start shows around 6. Cruise, it will sit all day at 4. Might drop a bit at idle (maybe 2).
(This is a RB25DET)
https://www.sau.com.au/forums/topic/202418-oil-pressure/#findComment-3653294
This is HORRIBLE advice.
Get the thing moving as soon as you get it started. It'll warm up the oil and water a lot faster, and also warm up the oil in your gearbox and differentials. Keep it under 4000-ish rpm until it reaches normal operating temperature.
https://www.sau.com.au/forums/topic/202418-oil-pressure/#findComment-3655288
hahaha so right agreed man
https://www.sau.com.au/forums/topic/202418-oil-pressure/#findComment-3664698
I was concerned 'bout the pressure on my R33 GTR. It never went above 4.5 and sometimes dips under 1 bar :)
So I bought a cheap AutoGauge pressure gauge to keep an eye on it. It was the stock gauge in my case. Around 2 Bar both read about the same. But above 3-4 the AutoGauge keeps climing to 6-6.5 where the stock one stops at about 4.5. Also on days when it drops below one the autogauge still reads 2+. On those days the stock gauge never goes above 2.5 but the AutoGauge still reads ok all the way to 6.5. I have no idea why some days the stock gauge does that and other days its ok.
Personally, I have too much invested in my car to have it malfunction due to oil issues. Oil problems are a definite way to stuff the motor.
Well, at least I have peace of mind now. If ur interested I bought the AutoGauge smoke face 52mm for $27 + 6 shipping to Sydney from an online shop (PM if you want the details). I was doing an oil cooler and remote at the same time so I didn't have to really fuss with a special adapter for the oil pressure sender unit.
Edited by Pezhead
https://www.sau.com.au/forums/topic/202418-oil-pressure/#findComment-3673737
Shouldn't the Oil Pressure gauge be quite high on start up? Its gota get the oil pumping through the system and after warm up the pressure drops.
djr81 Thats quite interesting on what you said, I never new that.
Edited by (00)SKYLINE(00)
https://www.sau.com.au/forums/topic/202418-oil-pressure/#findComment-3673757
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
