  • Replies 47
thanks heaps for posting up that viewing pleasure!!
im surprised at the gallardo it is a fair beast and extremely nimble..... as for gtr vs gt3..... :) they are both heavy big 4wd's and im happy that nissan could come up with something to rival porsche from stock.
as for the nsx :( c'mon its n/a and likea 3 litre..... it does realy well for what it is id love to supercharge one!
jenkies :D
im surprised at the gallardo it is a fair beast and extremely nimble..... as for gtr vs gt3..... :rofl: they are both heavy big 4wd's and im happy that nissan could come up with something to rival porsche from stock.
as for the nsx :) c'mon its n/a and likea 3 litre..... it does realy well for what it is id love to supercharge one!
jenkies :ermm:
The GT3 isn't 4WD, its RWD and only around 1400Kgs from memory
Those gearchanges on the Lambo looked savage. The GT-R was the star of that race. The fact a stock, first generation GT-R made a hotted up Lamborghini work that hard for a win is such an awesome result. :ermm:
The 911 Turbo was holding up the GT3 something shocking...
Although it is understandable that they wouldn't be pushing those expensive, loaned, lumps of metal to 10/10ths for a friendly race :ermm:
Agreed, and Best Motoring is more race-o-tainment than a really impartial test of performance. But the laptimes and qualifying are pretty good as a reference.
I was disappoint with how the GT3 was held up, it has been my favorite car ever since it came out and I wanted to see how it would do.
Edited by Laurence
fantastic video thanks for the link.
There did seem to be some troubles with the porches as they didn't seem to be as aggressive in the corners as previous racers. Someone made a comment that the driver of the GT3 was complaining of understeer and poor tyres?
It is truely amazing to see a car in the price range of the GTR putting up such a strong fight against lambo's best. This to me brings back memories of the R32 :P more so than anything else about the car! It's great for god to be back.
I'm going to shot by a few ppls for saying this, The 35GTR brakes are going to catch fire under normal race conditions from what was in that video.
no you wont get shot. I will by the way thing are going around here...
I second that fo shizzle. :(:)
The thing that in sure many wont agree with is that the GTR was fading fast and that was only after 5 laps although i will admit it was most likely a combination of tyres AND brakes. The cars too heavy.
Had the GT3 not been held up by its slower sister, i think things would have been very different.
The Brakes on the GTR would have to be the achilles heel of the car would they not?
Edited by m3gtr
^ i would think not
can out brake the 911 turbo ceramic brakes, (in normal cast iron form) and in this case, the GTR was up against another ceramic brake packer, the Superleggera.
The V-Spec will surely have ceramic as an option, but definitely better brakes from standard. And with less weight, will be more than up to the task.
A fair fight is Superleggera vs. V-Spec, THEN can you compare brakes, etc...
Judging from that, a GTR would beat a normal Gallardo around a track.
so i disagree, the brakes aren't the weak point IF you compare it fairly against it's realistic competitors. Don't forget the Superleggera has 390kw's at around 1350kg. The standard GTR has less power and more weight!! And NO ceramic brakes. Now put THAT into the context of the final results. 400kg's extra weight (that is just an INSANE weight disadvantage), and ~40kw's less, i think the brakes did as well as you could expect considering it's main rival in that race
Great find! The GTR did well.
The other thing to remember is that this is the 1st generation R35 GTR. The 1st generation Gallardo was a significantly slower car compared to the current generation Gallardo let alone the Superleggera. But you have to test current models and the Gallardo is due for replacement soon.
It will be interesting to see what the Spec V ends up like. Lighter with more power and better brakes... YES PLEASE!!!
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
